I am in the process of trying to mold and cast several prop pieces generated from 3d models that have been prepared / sanded to a nice finish. Ideally, I would like to cold cast the items using the aluminum metal powder. I am familiar with the molding and casting process, however I am a little confused as to what works with what when it comes to the rubber, casting material, and release agents. I would like to have the pieces be very strong (and not very flexible) which has guided my initial selections below.
Here are my questions:
1) Would Smooth-cast 380 or 385 be appropriate for this purpose? Which one is more appropriate for mixing with metal powder? I also considered Smooth-cast 325 but from reading it seems like 380/385 would create a ‘stronger’ or ‘harder’ cast.
2) For the mold, would OOMOO 30 be sufficient or is there a better option? I’ll be using boxes I built and oil based (non-sulfur) clay during initial molding.
3) Lastly, would Ease Release 200 be appropriate as a releasing agent assuming the mold & casting choices above? From what I read it will work with silicone & urethane resins.
Thank you for any pointers!
Chad
Chad
