Tips I posted on another thread.
This is based on a lot of help from Marcus, others, and a lot of reading.
You will need a Singlepoint Scope.
Singlepoints are the first red dot scopes. No batteries and you can't see through them. You keep both eyes open and natural light creates a red dot in the scope and with both eyes open you see your target with the dot. Takes some getting used to but it works.
The cone tipped version are the ones from the film including the bowcaster. Good luck finding one. Been hitting search everyday for 6 to 7 months and have yet to find one. Most ones today also seem to have clouded tips. The round end one comes up sometimes. I've seen three in the last 6 months but be sure to hit Worldwide on Ebay as most seem to be in the UK. Gonna run about $80 to $100. Much cooler than a resin copy. As for the end get a clear end of a spray bottle that matches the one on the cone tip. Throat spray ones work but there is writing on them. The best I found is on a bottle of whiteboard cleaner for classroom boards but you need to check in person to make sure it has the nice clear hard plastic cap and not a different one. I have had several and most have the right one. It's nice and clear and matches the scope perfectly. If you want to modify the end to match the cone tipped one you can but the scope may not work anymore. The round tip end part that's red is different between the round and cone tipped. I left mine so it still works.
8 oz. white board cleaner like the one I used:
EXPO White Board Cleaner 8 Oz by Office Depot
You need a very specific type of scope rings so it will be screen accurate but also so you can mount your other two scopes on either side of the Singlepoint.
Can't think of the name of them off the top of my head. Marcus pointed me to a set. They were not expensive. $5 or $10 bucks.
Will think of it sooner or later.
Marcus will be around soon. He can't resist Bowcaster talk.
Side Scopes.
Two Model 7 4X20 scopes from Japan were used. Know one knows what brand as the box does not have it. Only Marcus has a matching set as far as I know and it took years to find and several had to be bought to get and/or create a matching pair.
A alternative that is nearly exact and really only Marcus could tell the difference, as he has a Screen Accuracy Sickness or SAS, is Nikko Stirling 4X20 Scope. These are what I use and they look great. It also may take several tries to get a matching set but both of mine were less than $20 and that included shipping from the UK. Like the Singlepoint that seems to be where they are from. I got lucky and both mine matched except for one small part that Marcus had given me with some spare parts when I bought the Bowcaster from him. Mine have slightly different writing and I wan't to leave them un-painted so I am still gonna keep looking. They don't come up very often. Three in the last 6 months but they are cheap.
Once you have the Singlepoint with the proper scope rings you just mount the Nikkos on either side of the Singlepoint's scope rings. I'll take some pics to show you mine later.
Side Scopes.
