Hi Evan
I left the front section in it´s current state until I figure out how to make the front-sight assembly and what bow to use.
The finish is just temporary, since I wanted to check the frame for any areas that still need some attention and I couldn´t make these out with the grey primer on :unsure
As I can see all of us started with the metal bow, that came with the safari. You decided to custom make a new bow out of aluminium, Marcus went with the original for now (so do I). The curvature of the metal bow is perfect IMO, but the stamped metal is inaccurate.
I was thinking about purchasing a barnett commando replacement bow and "carving" in the correct curved shape to it´s lower edge. But while you can get a "regular" bow for about 30 Euro, these bastards charge 90 Euro for a Commando fiberglass bow :eek
Any other ideas where to get an accurate replacement bow????
Marcus:
Your Safari frame looks great so far.
For accuracies sake I would have to remove the section on mine as well, but I left it -as you guessed- to make attaching the sideplates easier.
Anyway, even with a completely hollowed out frame you should be able to get these on properly. Think about drilling/ threading holes opposite to the detailing of one plate. Use some longer screws e voila. Will have to check if the placement of the sideplate-detailing is pretty much mirrored on the left/ right, which would make things much easier
Markus
