KJC
So, the title should be self explanatory. I am going to be casting my first urethane rubber cowl and I need advise. I have scoured all over and can't find a good walk through on the full process for casting urethane rubber cowls/masks.
What I know so far:
I will be roto-casting or "slush" casting.
Vitaflex 40 seems to be the preferred rubber (this has a stock pot life of 30 mins with a cure/demold time of 16 hours)
I can use Kick-it to make the urethane cure quicker.
I have just found a rubber from Polytek called PT-Flex that is available in varying shore hardness (though they don't have a 40 shore). This is described as low viscosity and quick curing which seems ideal for roto-casting.
What I want to know:
If I go with the Vitaflex, how much Kick-it should I use? I found the guide on the Smooth-On site, but what is the recommended ratio?
Does anyone have experience with the Polytek PT-Flex urethanes?
How thick does a cast have to be to reduce risk of tearing?
Should I try to cast in a single pour or how many layers should I cast?
Is there a way to clean up the lumps or run marks on the inside after casting or how do I avoid these?
Is there a way to correct thin spots if there are any in the final casting?
I'm sure I'm not the only one who would benefit from a nice full guide on this. Like I said, I have been searching and have not found one.
What I know so far:
