Casting Materials for combat weapons?
Aiden26
Member
So In this feature length Saga I am doing, they use many weapons such as swords, shields, axes, daggers, etc... So here's what's going on. I found someone to make custom pep and foam files for costumes and props. For props I will be making molds, but there's one thing I need to solve. The props will be used for combat so I need a casting material that is strong enough to handle this task. I did research on Simpact 60A witch is a high impact resistant urethane. And it`s quite strong. But for blade weapons I want to get the edges to 4mm. But it gets flimsy at that thickness. Would it be fine if the prop was thick down the middle and got thinner as it gets closer to the edges? Also would anyone know of a different casting material that would work? Any help is appreciated. Thanks!
-Aiden
