AsgardBarbie
Ok, caveat is that this will be slow to update. I'm building it simultaneously with another project, and they're both doozies. And before I begin, I need to say a HUGE thank you to user Fly4v for answering all the questions Google Images failed me on.
This is the render I came up with:
I'm making it for my partner, so I happened to have a pattern block already made for him. From there, I got the pants pattern. (I'll tackle the shirt when I'm done with the pants.) After scrutinising seamlines, there are nearly 50 pieces.
This is the part where I SHOULD have stopped, had a vodka tonic, and called it a day. Instead, I soldiered on (ahaha, soldiered,) and after days of tracing and top stitching, found myself with a leg.
Upon realising my partner does indeed have TWO legs, I may have baked a few dozen cupcakes simply because it wasn't sewing. I've also got a bit of the busy work out of the way, figuring out the dye formula I'm going to use and working through the closure methods for the top. We ordered a shield (aluminium, I'll be painting it myself, so that'll be fun...) I also made pouches, because there will be a belt eventually.
Like I said, SUPER slow build, I'm aiming to have this finished by April 2015 -- but I can only handle so much topstitching in a day, y'all. Updates as I have them. =)
x, Barbie
x, Barbie
