can i fiberglass a pepakura model stuck together with pva
firebapx
most americans call it elmers or i think thats the brand made a predator bio mask and i stuck it together with pva i need to know what i can do any help please guys
most of the foam builds on here are coated with pva then resined before fiberglassing, so the short answer is yes you can but i dont think it would turn out very good if you skipped that step
Hey firebapx, I ONLY use Elmer's on the tabs for every pep project I've done. I have never had a single issue with the fiberglass resin interacting in any way with the Elmers.
You should be good to go.
I coated a foam mannequin head with pva then added resin an fiberglass mat and did my sculpting head armature
thank you very much this is the detailed precise information i have been looking for i think i just read some where you should only use a hot glue gun or it will fall apart. youv been a great help now weather permittion i can get out tomarrow and fiberglass my first ever project a predator bio mask :)
