You should be able to do that. You may want to put some filler in the resin to thicken it if it is watery thin. That way you can build up a thicker layer that will support your mask without it running all over the place.
It may or may not adhere to your mask very well. Urethanes usually stick pretty well, but your cowl has been cured for a while, and may have oils/dirt that would inhibit adhesion. But then again, that might make it easier if you ever want to remove the rigid core.
