BSG Viper Parts ID's
division 6
Hello, I'm hoping some of you can help me out.
I'm looking for good reference images or pictures of actual model parts used on the Viper.
The areas I would like can be seen in the image below.
Starting at the front I have a part that looks like the piece with the white arrow but don't know what the rest of the parts looks like.
Area 2 near the cockpit the piece inside the slot I have the ship gun piece.
Area 3 the detail bits inside the intakes.
Area 4 the oblong piece on the exhaust.
I know that the last part is actually two parts wrapped around the engine I just need a clear image to scratch build them.
I am using the reference to make the Monogram / Revell more studio accurate.
I've already started on the back end that ironically is more accurate on the originals (70's missile firing) than the 30th anniv.
Any help will be greatly appreciated.
Thank You
Eric...
Pieces in intakes are from a T-34 tank tread (one of the links). It'll be tiny on the Monogram kit.
The exhaust cans are from the Hasegawa Leopold kit, wrapped into a cylinder. They are to top deck of one of the trucks. The part is trimmed so it looks like it is a separate part stuck on top, but it's not.
Part #1 is also from the Leopold kit.
Gene
Thanks.
Alls I need are pix of the parts so I can make them of see if I have something similar in my parts box..
Eric...
Hi hope you don't mind my 2 cents but...
This "nut has been cracked" check out some of the other older threads regarding the Original BSG viper
All kit parts have been identified.
I've spent weeks going through every viper thread I could find here and on other forums and have even looked at others builds but have not seen these parts in detail.
Unlike most people I do spend large amounts of time looking before asking questions.
If I missed it than fine I will look again but more than likely all the info has dropped off the board.
These parts are pictured at Resin Illuminati here. They're in the reference section, you need to be logged in to see it, so you'll need to register if you haven't already. But they show everything you're looking for.
