BOWCASTER PARTS RUN
_(Finalized Parts Being Made And Pictures Of Each Part Coming Soon!)
(Rendered and prototype models shown)
**BARRELS JUST ADDED**
**Model 7 Lettering and Inspection Stickers Limited Run Thread Link Below (Separate to this run)**
Hello fellow bowcaster fans! After countless hours and years of research I have modeled and built almost every part of the bowcaster.
Having lots of positive encouragement, I have decided to start a very thorough and detailed run for the following parts, (Front Sight, Barrel Mount, Barrel Support/Hinge, Trigger Cover, Scope Mount, o-ring straps, and Barrel.) Plans for additional parts in the works!
Details for each part below.
If you are interested and would like to be put on a current list please send me a direct message with the following (Username, Name, Phone Number or Email, Mailing Address, and Each Part You Are Interested In).
I will add names to the lists in the order they are received. If you don't see your name on a list within 2-3 days, please message me until you see your name on the list.
This run will have limited spaces available for each part respectively, but any interest beyond the current lists' available spots will be put on a waitlist until I am able to make more parts. Waitlists are not guaranteed to turn into current lists.
Once you are on a current list you are committed to purchasing the parts you have selected, however, you will not be required to pay any down-payments or pay in full until I am ready to ship your parts to you. Once parts are ready to ship, I will confirm your mailing address, update your invoice to include actual shipping costs, and then ship them after confirmation of full payment.
All parts are handmade by myself, and production times may vary.
As each part is made by hand, minor variances may exist.
Each part has been very carefully studied and closely matches the specs of the original bowcaster from dimensions to bends. All the hardware used for these parts does dimensionally match the original bowcaster as well.
If you have any questions, don't hesitate to ask.
Thanks for your interest!
Notes: PRICES DO NOT INCLUDE SHIPPING COSTS
(you will be required to pay actual shipping costs once calculated with your address)
Anyone outside the US please contact me as shipping costs may be higher
All pieces come UNPAINTED and will require you to finely polish and paint each piece, Rust-oleum satin black recommended
All pieces are shipped unassembled. If you need help on reassembly, please don't hesitate to ask
All prices are in USD.
_____
Front Sight $60.
Finalized Pictured
_____
The front sight is made from a block of solid aluminum and includes both arms made out of aluminum flat bars which are bent to match the original bowcaster. Also included are the 4 mounting bolts and 1 set bolt. All the mounting bolts do match the sizes on the original bowcaster.
What's in the box
1 main body
1 left arm
1 right arm
4 mounting bolts
1 set bolt
Current List 22 spots available (Wave 1 Filled) |
7 spots available (Wave 2)
Waitlist
_____
Barrel Mount and Brackets $85.
Rendered Model and Prototype Pictured
_____
The barrel mount block is made from one block of solid aluminum and includes the left and right brackets which are made from aluminum flat bars. They are bent to match the original bowcaster. Also included are 4 mounting bolts, 1 set bolt, 2 flat headed screws, 1 slotted screw, 1 nut (for slotted screw), and 2 washers. Each piece of hardware was carefully measured and dimensionally matches the original bowcaster.
What's in the box
1 main block
1 left bracket
1 right bracket
4 mounting bolts
1 set bolt
2 flat screws
1 slotted screw
1 nut
2 washers
Current List 16 spots available (List #1 Filled) | 2 spots available (List #2 Filled) | Waitlist available
Waitlist
_____
Barrel Support and Hinge $220.
Rendered Model Pictured
_____
The barrel support is made from one block of solid aluminum and is shaped to match the original near perfectly. The support has the correct rounded bottom, sloped front side, and tapered right and left sides. The hinge is made of 3 solid steel bar pieces. The left and right fingers are attached to the main bar by a series of welds which is how the original hinge was presumably done. You will also receive 1 flat headed screw and 1 chicago screw set to attach the support to the hinge.
What's in the box
1 main support block
1 steel hinge (with left and right fingers attached via welding)
1 flat headed screw
1 chicago screw set
Current List 16 spots available (List #1 Filled) | Waitlist available
Waitlist
_____
Trigger Cover $40.
_____
The trigger cover body is made from 16ga steel sheet and folded to as closely match the original bowcaster as possible. It comes with 3 mounting screws and 1 knurled nut that matches the size of the original bowcaster. (Suggested to buy scope mount in addition to ensure parts fit together)
What's in the box
1 steel cover body
3 mounting screws
1 knurled nut
Waitlist
_____
Scope Mount $65.
_____
The scope mount is made from a solid aluminum bar, includes 1 steel scope ring mount plate, 4 mounting screws, 4 compression springs, and 1 cheese head screw. The cheese head screw dimensionally matches the original bowcaster. (Suggested to buy trigger cover in addition to ensure parts fit together)
What's in the box
1 main body
1 mount plate
4 mounting screws
2 springs
1 cheese head screw
Waitlist
_____
O-ring Straps $5.
Finalized Pictured
_____
The o-ring straps are made from an off color olive green canvas with slight tan hues, and are then dyed with coffee to give it the correct brownish tint. The straps are cut to match the length and width of those used on the original bowcaster, as well as match the original coloring.
Does not come with o-rings and buyer will need to cut holes/etc for mounting the straps.
WARNING: DO NOT WASH
What's in the box
2 olive green/brown canvas straps
Current List 20 spots available
Waitlist
_____
Barrel **Just Added** $40.
Finalized Pictured
_____
The barrels are custom extruded steel and are made to match the length and diameter of the barrel on the bowcaster. Since each barrel is individually extruded minor variances may exist. The outer surface is lightly polished.
Display stand not included.
What's in the box
1 Custom Extruded Steel Barrel
Current List 19 spots available
Waitlist
_____
Thread Link Below! (Separate to this run)
www.therpf.com
_____
Disclaimer:
There are no refunds or exchanges, and seller is not responsible for any injuries and/or damages associated with the receipt or use of these parts.
As always, if you have any questions, please do not hesitate to ask.
_____
Front Sight $60.
Finalized Pictured
_____
What's in the box
1 main body
1 left arm
1 right arm
4 mounting bolts
1 set bolt
Wave 1 1. Cameron 2. Jamesfett 3. Enaswede 4. Portumac 5. Mandingalow 6. Russellsch 7. Tatooinemachine 8. Starwarrior 9. Kitjunky 10. Ecojedi83 | 11. Odiwan72 12. Mgoob 13. damon5973 14. Ecojedi83 15. Seneca 16. Seneca 17. Newmagrathea 18. Blindvoyeur 19. lmc3 20. Cyberblock | 21. Jetsetwilly 22. GotWookiee Wave 2 1. 3dimpact 2. Protocoldroid 3. dandirk 4. 77bandit 5. Slave1 6. 7. |
1. |
_____
_____
What's in the box
1 main block
1 left bracket
1 right bracket
4 mounting bolts
1 set bolt
2 flat screws
1 slotted screw
1 nut
2 washers
List #1 1. Cameron 2. Jamesfett 3. Enaswede 4. Portumac 5. Mandingalow 6. Russellsch 7. Tatooinemachine 8. Starwarrior 9. Kitjunky 10. Ecojedi83 | 11. Odiwan72 12. Mgoob 13. damon5973 14. Ecojedi83 15. Seneca 16. Seneca | List #2 1. Newmagrathea 2. Blindvoyeur |
1. lmc3 2. Cyberblock 3. Jetsetwilly 4. GotWookiee 5. 3dimpact 6. Protocoldroid 7. dandirk 8. 9. 10. |
_____
_____
What's in the box
1 flat headed screw
1 chicago screw set
List #1 1. Enaswede 2. Mandingalow 3. Russellsch 4. Tatooinemachine 5. Jamesfett 6. Starwarrior 7. Kitjunky 8. Ecojedi83 9. Odiwan72 10. Mgoob | 11. damon5973 12. Ecojedi83 13. Newmagrathea 14. Moet19 15. Blindvoyeur 16. lmc3 |
1. Cyberblock 2. Jetsetwilly 3. GotWookiee 4. 3dimpact 5. Protocoldroid 6. dandirk 7. 77bandit 8. 9. 10. |
_____
Trigger Cover $40.
_____
What's in the box
1 steel cover body
3 mounting screws
1 knurled nut
List #1 1. Cameron 2. Jamesfett 3. Enaswede 4. Portumac 5. Mandingalow 6. Russellsch 7. Tatooinemachine 8. Starwarrior 9. Kitjunky 10. Ecojedi83 | 11. Mgoob 12. damon5973 13. Ecojedi83 14. Newmagrathea 15. Seneca 16. Moet19 |
1. Blindvoyeur 2. lmc3 3. Jetsetwilly 4. GotWookiee 5. 3dimpact 6. Protocoldroid 7. dandirk 8. 9. 10. |
_____
Scope Mount $65.
_____
What's in the box
1 main body
1 mount plate
4 mounting screws
2 springs
1 cheese head screw
1. Blindvoyeur 2. lmc3 3. Jetsetwilly 4. GotWookiee 5. 3dimpact 6. Protocoldroid 7. dandirk 8. Slave1 9. 10. |
_____
O-ring Straps $5.
Finalized Pictured
_____
What's in the box
1. Jamesfett 2. Enaswede 3. Mandingalow 4. Russellsch 5. Tatooinemachine 6. Starwarrior 7. Kitjunky 8. Ecojedi83 9. Mgoob 10. damon5973 | 11. Ecojedi83 12. Newmagrathea 13. Blindvoyeur 14. lmc3 15. Cyberblock 16. Jetsetwilly 17. GotWookiee 18. 3dimpact 19. Protocoldroid 20. dandirk |
1. |
_____
Finalized Pictured
_____
What's in the box
1. Jamesfett 2. Tatooinemachine 3. Newmagrathea 4. damon5973 5. Mgoob 6. Russellsch 7. Kitjunky 8. Blindvoyeur 9. Mandingalow 10. Cameron | 11. lmc3 12. Cyberblock 13. Jetsetwilly 14. GotWookiee 15. Enaswede 16. 3dimpact 17. Protocoldroid 18. dandirk 19. Portumac |
1. |
_____
Limited Run - Replica Model 7 Scope Lettering Stickers and Inspection Stickers
Limited Run for replica model 7 scope lettering stickers and inspection stickers that are able to be put on regular scopes to make them look like actual model 7 scopes. These can be used for the bowcaster scopes, Dr Evazan's blaster scopes, etc. Message me if you would like to place an order...
_____
Disclaimer:
