Mutant-Enemy
Hello Gents,
I'm hoping someone out there can give me some suggestions on how to wire up some lighting for a project I've been working on now for a number of years off and on.
I started this borg cube a loooong while back and have been collecting greeblies and adding to it bit by bit.
A while ago I came across some EXIT Sign LED reflector Banks
(First photo) that were being pitched in the garbage because the newer styles were coming in.
Nothing is wrong with them,I got a lot of them too and they are GREEN which is perfect for my case.
I want to wire them up so that I have two per side (inside) the cube which is large (Each panel is 23" X 23")
Problem being is I have no idea how to do wiring and I hope someone can help me out with suggestions.
Each reflector bank comes with a plug (pictured last) and I have a lot of these plugs as well.
Anyway, take a look if you have the time and hit me with your suggestions and questions if you will.
