Book of Boba Fett: Mechanical question for Sedgley flare pistol owners?
Rook 3
Already asked at TDH, but no responses.
I have and original flare pistol, but I'm wondering something about it.
The shell eject/extraction lever extracts when opened, but when you shut the barrel doesn't close until it hits the flat face of the firing pin area. Is there supposed to be a spring or something in that lever mechanism that makes it close itself? Or is it just closed by rubbing against the flat plate?
thd9791
I believe you're correct.
1) the floppy plate under the barrel hits the receiver when the gun is opened, bracing it, which pushes the extractor out and keeps it out.
2) I have a perfect rectangle of scratches on the flat plate, so I believe the plate pushes it closed.
There isn't a spring as far as I can tell, and it's pushed by the two pieces of metal back and forth
