Hazmat
Like the title says, does more hardener equal more hardness, or just shorter cure times? Obviously if I don't use enough hardener The Bondo won't cure at all but will I have an easier time sanding if I use less hardener? Will I have a stronger product if I use more hardener?
Same question for rondo, if I use one hardener instead of the other will there be a difference in hardness? will it be harder if I use both?
I've been using bondo and rondo quite a bit lately and sometimes I could swear this stuff is impossible to sand, other times, not so bad. I'd like to know if it's just me.
also, has anyone tried mixing regular old wood filler and bondo resin?
