Blade runner blaster - metal Coyle
Discussion in 'Replica Props' started by spoudastis, Aug 24, 2015.
  1. spoudastis
    spoudastis Well-Known Member RPF PREMIUM MEMBER
    785
    A few months ago I purchased my full metal Coyle blaster and I finally have had time to get started on it between moving and the birth of my second child. This is going to be a slow burn build but I wanted to keep a log of my progress.
    The project started with me contacting Rich about picking up a couple of metal pieces to upgrade my Coyle CS+T resin blaster and progressed to me very quickly succumbing and purchasing a full metal kit. I build models and am fairly experienced but this is the first time I have tackled anything like this. Wish me luck.
    The obligatory shot of all the pieces lovingly set out on the bench ready to go.
    And the inner grip frame. This was a test piece just to get used to the material and see what I needed to do to get a nice shine on the parts. I started with 80 grit to rough out the shape and worked down to 1500. I'm waiting on some buffing pads to arrive from Amazon to finish it off but so far the process seems promising though there are still a few scratches.
    Hopefully more to come soon.
    mugatu likes this.
  2. I Athena I
    I Athena I Active Member RPF PREMIUM MEMBER
    212
    I have to say that this Blade Runner blaster is one of my favorite weapons!
    I can sympathize for your build a head. My dad made one and then converted
    it to, live fire. It's so cool. I can't wait to see the rest of your build. Good luck!
    :thumbsup
    ~ I Athena I
  3. asalaw
    asalaw Sr Member
    1,681
    Is that cast aluminum? Looks like it. Don't forget to try a Scotchbrite pad on it. Works great on metals.
  4. spoudastis
    785
    It is cast pewter. It is quite rough in its raw state but with some work it polishes up to almost a chrome shine.
    asalaw likes this.
  5. asalaw
    asalaw Sr Member
    1,681
    Nice! :)
  6. whitehammer
    whitehammer Well-Known Member
    566
    where can this kit be had?
  7. spoudastis
    785
    Pm sent
  8. Sean
    Sean Sr Member RPF PREMIUM MEMBER
    2,286
    Cool beans! subscribed...
    may I ask what kind of buffing pads your waiting on? I'm attempting to build a ghost with one of Rich's kits. rough going so far..
  9. LB66679
    LB66679 Well-Known Member RPF PREMIUM MEMBER
    567
    wow ! i would love to build one of these
  10. spoudastis
    785
    Nice, good luck with the ghost, I love the way those look. These are what I ordered on Amazon:
    http://www.amazon.com/gp/product/B000XAQCI6?redirect=true
    i tried a buffing wheel in my grinder and it didn't work so well, hoping these give me a better shine with the dremel. The progression i used was 80, 150, 220, 320, 400, 600, 1200, 1500. And it turned out pretty shiny with a quick buff with a rag. I have read that hitting the parts with mag wheel polish after the sanding really makes a big difference as well. Good luck, and I'll let you know what ends up working best for me.
  11. Sean
    2,286
    Thank you very kindly. and I think you will do a fine job with your build.
  12. brandomack
    brandomack Sr Member RPF PREMIUM MEMBER
    2,040
    The order i follow, file carefully with jewelers files. Sand with 180, 220, 300,400.
    then buff with this stuff..
    http://www.nevrdull.com
    a wipe with a lint-free cotton rag, and the piece is ready.
  13. spoudastis
    785
    I'll look into that. When you say you buff, do you buff with a machine or by hand? And the polish will get the piece scratch free even after only 400 grit? Thanks.
  14. spoudastis
    785
    Hit it the inner grip with mag wheel polish and man what a difference! It looks like polished stainless steel, makes me consider doing a ghost now :D. In the first image you can see the reflection of the camera and my shirt.
  15. spoudastis
    785
    Got a chance to work on the butt plate. This will be the last of the in progress polish pics as from now on I will be roughing out the parts and then fitting them before refining and polishing. Started with 80 on the belt sander to get the bottom flat then progressed up to 600. Polished with my dremel then with mag wheel polish. You can still see some skratches so I'll probably go back at some point and redo this part, I just wanted to quickly see how the dremel polishing worked out.
    Sean likes this.
  16. mugatu
    mugatu Sr Member RPF PREMIUM MEMBER
    1,782
    Just found this! I LOVE this gun! I can't wait to see your finished piece.
    Quick question: I'm unfamiliar with handling pewter. I believe it is a soft metal. Is it so soft that one would need to be very careful handling the prop, once it's completed, to ensure not damaging it? For example, can you crease/dent/mark the pewter with a fingernail?
  17. Mechanized2400
    Mechanized2400 Sr Member RPF PREMIUM MEMBER
    1,731
    Good luck with the build! It's a time piece but well worth the effort you'll put into it. Getting one of Rich's blasters was my Holy Grail. Having one is by far my favorite prop, can't beat what he makes.
  18. spoudastis
    785
    Hope me you like the build I'm enjoying myself already!
    the pewter that Rich uses is an alloy, not 100% pure pewter, so it's not noticeably soft. It is easy to work but you would never damage the metal by handling it. Dropping it would do some damage I image though.
    mugatu likes this.
  19. spoudastis
    785
    Thanks! This and Hans greedo killer are my favorite blasters, but this ones design is stunning. I can't wait till I can have this one on display.
  20. joberg
    joberg Master Member
    2,900
    Keep up the good work! That polishing makes the difference for sure.
  21. spoudastis
    785
    Ok so now I have a question about the grip frame to grip alignment. I have looked at some online reference but can not really tell. As looking from the back, the left top side of the amber grip aligns with the grip frame and is straight across, see bottom right picture. The right side grip however dips slightly at the top while the grip frame is straight across. Should the grip frame be shaped to the amber grip or should the grip frame remain straight, see top right picture?
    Mechanized2400 likes this.
  22. Mechanized2400
    1,731
    I'd save leave be for the time and put to the side. If you haven't already, do a test fitting and check if the grip or the protruding metal is a problem before doing sanding/filing anything. There shouldn't be any issues though. I guess really it's up to you. But I've seen countless pictures of Mr. Coyle's blasters as well as mine, with that same piece protruding.
    spoudastis likes this.
  23. IFA
    IFA Sr Member
    1,046
    I would say that once you will have the blaster finished, you won't notice that "little" detail ;)
  24. spoudastis
    785
    Awesome thanks for the advise. Ill Leave it for now, and check out the worldcon photos later but I'm sure if both you and Rich leave that metal piece showing that's how it should be.
  25. Chuckisbaws
    Chuckisbaws New Member
    2
    How do you acquire this blaster kit?
  26. KramStaar
    KramStaar Sr Member
    1,960
    Contact Rich Coyle: racprops@cox.net
  27. spoudastis
    785
    kramstaar! Good to see you here. Your worldcon build is a huge inspiration for me, I visit your site at least once a week. If I can get my blaster looking half as good as yours I'll be a happy man.
    cheers
  28. KramStaar
    KramStaar Sr Member
    1,960
    The honor is mine, thank you very much for your kind words. If you want to contact Rich directly it might be easier to do it on Propsummit because he's regularly there.
    Good luck and I look forward to seeing how yours all works out.
    High regards
Share This Page
