so i have a creality cr10 and i printed all the parts off now its time for the sanding a lot of sanding every thing got rubbed down with 120 grit sand paper followed by 180 grit and finally 320 ready for priming i gave every thing a coat of adhesion promoter and 2 light coats of an automotive 2k filler primer
after every thing had been primed it got wet sanded with 800 wet n dry and painted gloss black or matt black ready for the netxt step
witch was to paint the gloss black parts in alclad 2 stainless steel
l
now for the grips i made a silicone mold of the 3d printed grips and cast them out of plane old polyester resin
so here is the problem i run in to polyester resin shrinks when cured buy about 5-7% it turns out. So i re printed re sanded re primed and re carst a 2nd set 8% bigger to allow for shrinkage
if u look close you can see the ones in the middle are a bit larger than the ones on the out side buy about 7% they got a good sanding with 320 and wet 800 and i give them 2 coats of 2k clear lacquer
all the sanding and painting done time to move on to put it together punished props has a wicked youtube video on this.
so here she is all painted and assembled now for a bit of weathering i just went with some bacis oil paint washes lamp black burnt sienna and yellow ochre
ok guys thank you for reading this if you have any feed back or would like any more in depth detail on anything i did let me know
thanks ram
