1. Welcome to the Project Runs Forum!
    Click here for details on becoming a Premium Member.
    Click here for the complete Classifieds Guidelines.
    Dismiss Notice
Limited Run Blade Runner 2049 - K's blaster....in Metal
Discussion in 'Project Runs' started by brandomack, Apr 10, 2018.
  1. faust1103
    faust1103 Active Member
    218
    Hi Brandon,
    Any more updates or pics to share?
    One thing I was wondering about:
    AFAIK pewter/tin is a rather soft metal.
    So won't the pewter parts bend or deform in some way if you put pressure on them? E.g. if you squeeze the trigger or the barrel?
    At least that is what I remember when handling tin soldiers as a kid.
    Thanks.
  2. brandomack
    brandomack Sr Member RPF PREMIUM MEMBER
    1,830
    I’m currently working on the part 2 of moldmaking video.
    I’m about to mold the barrel, the rail and the shroud above the trigger.
    As for your question,
    There is a 3D printed interior structure that is inserted into the barrel during assembly, the solenoid is held in place using this piece so there will be no deformation.
    I’ve actually tried to bend reject castings to see how strong they are. i’m satisfied with the level of strength they have.
  3. Matt009
    Matt009 Active Member RPF PREMIUM MEMBER
    462
    Looking pretty awesome!
    brandomack likes this.
  4. Gprops2
    Gprops2 Member
    191
    The lines look so clean. It's not easy to get clean castings like this. Nice work!
  5. brandomack
    1,830
    Thank you! I’m 1/3 of the way through molding the barrel, and my brain has been hurting trying to think ahead as well as inside out to alleviate any potential casting imperfection areas where bubbles could form.
    I had Skylu3Design model me a plug to aid in the molding process, which i had Rocketeer print on his Raise.
    I glued the plug in place with thin CA
    Taped off the barrel to avoid any unnecessary cleaning, and built a box to pour the clay into.
    After pouring, i added an air bubble escape fin for when i’m casting the pewter.
    I built a box and poured the clay.
    Removed box for better access to clean the piece.
    The barrel just prior to Mineral Spirits wash.
    Cleap-up, sprue, and air vent complete.
    After this, it was boxed and the first section of silicone was poured. It’s currently post- curing in my workshop with the heat cranked.
    I can’t put it in the oven yet, because my wax sprue would melt.
  6. rickhoward
    rickhoward Active Member RPF PREMIUM MEMBER
    362
    Exciting stuff - Thanks for the update!
  7. pnag
    pnag Well-Known Member
    915
    Wonderful stuff!
  8. pnag
    915
    Snap! I swear I'd not read your post as I posted mine :)
    rickhoward likes this.
  9. rickhoward
    362
  10. faust1103
    218
    Another update maybe?
  11. brandomack
    1,830
    2nd video has been shot, i’m currently editing it.
    stussy, pnag and enterprise0216 like this.
  12. enterprise0216
    enterprise0216 Well-Known Member
    566
    Keep up the great work looking forward to seeing the video.
    Topgun1984 and brandomack like this.
  13. faust1103
    218
    But how far are you with the build?
  14. brandomack
    1,830
    The electrical engineer just sent me this, its the concept for the circuit.
    As you can see, first switch powers the unit on, the LEDs power on with a “warm up” sequence. The trigger switch activates the solenoid. After a period of time of no trigger pulls (currently set for 5 seconds for trial purposes) the unit powers down (LEDs go through “cool down” mode.)
    Pulling the trigger during powered down status will not activate solenoid.
    ***Note*** the flickering of the LED is from the camera and will not be seen in person.
  15. faust1103
    218
    This looks all very good.
    But why would the unit power down by itself after 5 trigger pulls?
    Surely in a firefight one would not want the gun turn off by itself?
  16. Serenity
    Serenity Sr Member RPF PREMIUM MEMBER
    1,785
    Probably to conserve battery... because it's just a prop. Lots of props are like that, from Farnsworths to various blasters out there, they run on a timer starting from the first or last motion or button press.
    In any case, he didn't say five trigger pulls, he said five seconds after the last trigger pull and it's just for trial purposes so far.
  17. brandomack
    1,830
  18. stussy
    stussy Active Member
    227
    faust1103 think you have misread what brandomack has wrote.
  19. faust1103
    218
    Ok, got it. My bad.
    Maybe it would be better to have a 10 minute intervall before the blaster turns itself off.
  20. brandomack
    1,830
    I’m probably going to go with 90 seconds.
  21. TomVDJ
    TomVDJ Sr Member RPF PREMIUM MEMBER
    2,305
    I think indeed anything above 20 / 30 seconds and below 5 minutes would be fine, no? If this was a real weapon, I guess it should NEVER power down by itself...
  22. PicasoX
    PicasoX Active Member
    211
    Nice!
    I love watching this unfold as we go.
  23. Swordsmith
    Swordsmith Member RPF PREMIUM MEMBER
    103
    /head desk- I assume orders are closed?
Share This Page
