Best adhesive material for Stress foam
Navarr
I have made a chest and back plate armor piece using the anti stress foam mats. I am going to connect the two pieces using nylon straps.
What would be the best material to connect the straps to the foam pieces?
thanks in advance
NICK
Contact adhesive is always a good bet for foam. 3M make a bunch of spray versions like super 77. I'm not sure exactly what you're wanting but doing a little stitching will make the join infinitely more robust. mechanical bond > chemical bond
hope that helps
Your half right Nick, you sew the straps or elastic to a piece of fabric that's larger then the strap and Glue that piece with Barge or Spray 90 should be stronger.
