Hey everyone. I've been a big batman fan all my life and thought after stumbling onto a youtube video about pepakura,thought I'd try my hand at it.
For me the main problem was that I live in an apartment with a toddler, so it had to be as non-toxic as possible. So after doing some research I found a video that stealth (huge thanks to stealth on all his awesome tutorials) did about the product epoxamite as a non toxic alternative to resin. I still resined it outside just to be on the safe side but it was great. No fumes, no bad smell, nothing.
Next was the bondo process. Rpf user MightyJohn (big thanks to you sir) wrote a very in depth post about using joint compound as a alternative to bondo and was gracious enough to answer some questions that I had. The joint compound worked out great and I highly recommend it to anyone who can't work with bondo for some reason.
I actually used 2 separate pep files. Im sorry that I can't give credit to the designers cause I don't know who they are (if you know who they are please let me know).
The original files were great but I messed up quite badly on some parts while peping so I performed 'pep surgery' and merged the salvageable parts of each to form one helmet.
Also while the size fits perfectly when on, the hole for you head was much to small for my head to fit in so I decided that instead of having a gaping hole showing the back of my head, I would cut out a piece and have it reattached by rare earth magnets.
So after close to 6months of nights working on this along with 8cans of primer and a ridiculous amount of sanding, I'm quite happy with the result. It's not perfect but I sure learned a lot that will help me for my next project. Hope you enjoy.
View attachment 128230View attachment 128231
I ended up using the face of the first file and the ears and back of the file on the right
View attachment 128232View attachment 128233
View attachment 128234View attachment 128235
I used Epoxamite insted of polyester resin
First layer of joint compound
Attemped to carve the scowl in with a file..... not too impressed with it.
View attachment 128238View attachment 128239
Here i used a 2 part putty and i think it did the trick pretty well
