Now on to everyone's favorite part. The mask is essentially a burlap bag covering a partial gas mask. The only time anyone ever sees the gas mask, however, is when the whole assembly is being put on or taken off. In other words, there's no point in making yourself uncomfortable by adding it, and gas masks tend to be expensive.
To find your burlap bag, try feed stores, plant nurseries and international groceries, where staples like rice are often sold in sacks. Tip: Burlap is also called "jute". If you have no luck locally, there are online resources. To decide which size you'll need, use a cloth tape measure to find the circumference of your head at its widest point, which is probably around the ears. Once the bag has arrived, kids should have the help and supervision of an adult to continue working on the mask.
The width and height of the bag you order may be reversed from what you need. That's no problem. Just rip open one side and sew the top shut with some matching thread. The Scarecrow's bag mask is in very rough shape, so don't worry about making your sewing pretty.
When you try the bag on for size, gently use a marker to indicate where your eyes are. After you remove the bag, carefully use a knife or other sharp object (an apple corer would be perfect) to punch holes through the marks that are big enough for you to see out of.
Again, the rougher the holes are, the better. You'll probably wind up with a ragged fringe. Make sure the fringe is pushed outwards so that it doesn't irritate your eyes.
The Scarecrow's mask has thick, black cord sewn in a jagged line to close a hole in the bag over his mouth. Similar cord should be easy to find at any fabric store.
There are a number of other jagged rips in the bag that have been sewn shut with twine. The twine by itself will accomplish the look you want without the need to actually rip your bag. Twine is available at hardware stores and most supermarkets.
For most people, the scariest aspect of The Scarecrow is the brown, worm-like things that appear to come out of the mask. You can imitate this look (and save yourself some sewing) by buying some wild rice and glueing it into place where the mask's rips would be. Hot glue should do the trick.
To complete your ensemble, make a small, fake hangman's noose. This will hang loosely around your neck, giving the bag more of a head shape.
Buy some lightweight, natural fiber rope. Create the "knot" by hot glueing together coils of rope that leave enough room inside for two strands of the same rope to be pulled through. Drape a 3 foot length of rope around your neck and thread the ends through your "knot" like a bolo tie.
The goal here is to make sure that a yank on the rope won't hurt you. Angle the knot to one side of your chin so that it can be seen.
Lastly, for those who want to add an extra punch to their costume, The Scarecrow appears on horseback towards the end of the film wearing a full-body straight jacket as an overcoat. (It's undone, of course.) These are practically impossible to find, so you may have to create your own. The link at the beginning of this article has a photo to guide you.
