Avengers 2 Hulkbuster Iron Man Mark 44 Veronica Build, WIP
SFArcher
Hello everyone , this time I want to share with you this project which I have spent several months of work .
It has a height of 2.40m (almost 8ft) and has an internal wooden frame based on of James Burton´s hulkbuster design, allowing it to stand freely without anyone inside.
If you like I can upload some pictures of the assembly process , and if you have any questions I will gladly answer , hope you enjoy it .
A Hand
Torso´s inner frame
Jmen
View attachment 504927View attachment 504926
A Hand
Torso´s inner frame
There is only few people, who work with this suit. you are one of us))) awesome suit. :thumbsup
Shadeling
A Hand
Torso´s inner frame
Amazing work Love it :)
shsims
By chance do you have pep files, or is it from scratch. If you have files may I get copies, I want to build that duit
Sent from my SM-N900T using Tapatalk
IronMeg
Looks awesome so far! Is it meant to be a statue? Tell us a little about the process. love it so far!!!
shsims
is that 1/4 " white foam board your using for your constrution?????
is that 1/4 " white foam board your using for your construction?????
SFArcher
Looks great. Are those shoulder rests below the wood frame in the last picture?
Yes they are
By chance do you have pep files, or is it from scratch. If you have files may I get copies, I want to build that duit Sent from my SM-N900T using Tapatalk
Is not a pepakura build, The original design is based on the model of Paper replika. I modified files to suit my needs , to make my own files I converted to vectors and edited with Illustrator to have a modified and customized version, some sections and details are designed by hand.
And what did you make it out of??? Sent from my SM-N900T using Tapatalk
Wood, polywood, foam PVC, and some sections with eva foam coated with red potavin.
This costume can stand like a statue but the main objective is to use it as a suit which can suit up quick and easy when fully assembled, is designed to walk naturally and move arms and hands....
Looks menacing. Also curious about shell material.
3mm Foam PVC
BumblebeeRecycd
Hi, I am making my own, always great to see how others chose to tackle making it. Will you have your arms in the forearm ? Are you using lifts or stilts ? Have you thought about the vision issue ? Your progress looks amazing !
BumblebeeRecycd
Hi, I am making my own, always great to see how others chose to tackle making it. Will you have your arms in the forearm ? Are you using lifts or stilts ? Have you thought about the vision issue ? Your progress looks amazing ! Does the reference to Veronica mean you will have a piston fist ?
SFArcher
I'm using are 37cm high platforms and yes, the arms Will be in the forearms. About the vision issue, it will be a surprise when complete.
You can look at the inside of the legs here:
George
SfArcher,great job so far :thumbsup
I like the concept of using a costume with internal reinforcement as a statue
