AT-ST (first model for years!)
shaggy555
Here are some images of my first actual model build since the eighties!
About a quarter way through the paint... (Oh, first time using masking fluid and an airbrush!)
joberg
Good stuff all around...how did you find the kit? Easy to put together or some fitting issues? As for the first time using masking and an airbrush; you did a good job and I`m sure, it`ll improve over time with practice, of course. When doing the ``wear and tear`` kinda look, I can understand that this AT-ST is hitting some foliage and low branches, but it`s the feet who bear the brunt of the stress. Maybe more crap on those would be better...too clean compared to the rest ;)
JNordgren42
Member
Looks great! I just got back into things myself with a Bandai 1/144 RoS Millenium Falcon. It was a lot of fun and I sprung for a cheap airbrush for whatever I decide to build next.
shaggy555
Thank you... the kit went together very well (and got taken apart many times!) could've put it together in an hour...
Fit is amazing no glue required ( although various parts are glued now, with the photoetch modifications).
This is also only the first stage of the weathering, many more hours of streaking and griming on the horizon... I'm going for the worst kept AT-ST in the empire look...
I am also hoping to light the interior a la "The Mandalorian" (glowing red eyes!), and sort out a custom base, along with the Legion scale speeder bikes I just got..!
Hopefully more progress soon
Thanks for looking
JNordgren42
Member
thanks, +1 for cheap Chinese airbrushes, mine is great! (although nothing to compare it to...)
I had a Badger 150 when I was heavy into modeling, it's no Iwata, but it was a very nice tool. The last bit I need to hook it to my compressor comes this Thursday, so I can try it out and compare to my recollections.
BLADE and BRUSH
Be very careful if you intend to dirty it up with oil-paint or enamel washes. Enamel thinners and chemicals like turpentine will attack all of those tightly fitting joints. Cracks will form in the plastic and your model will fall to pieces. The AT-ST is particularly susceptible due to all of the tight leg joints.
shaggy555
So I have read... I am using exclusively acrylic paint on this, vallejo and meng mainly with a little bit of games workshop... I have the AK rust and streaking set (this has already provided the base rust colour ) and I am looking forward to experimenting with that ;).
Not sure, though, whether to clearcoat it before I start with the streaking (I have both gloss and matt, also acrylic ).
Any advice gratefully received!
shaggy555
On a slightly different note... now I've got the bug back... this will be my next project!
Again, any advice or links to build-ups would be very helpful (was kinda thinking of a diorama, maintenance bay maybe, and a little simple lighting!)
E Williams
The chipping looks amazing! How did you apply the masking fluid so finely? I always end up with really big chips (fine for props, but not right for scale stuff).
Analyzer
welcome back to modeling, off to a nice start for sure!
For the Viper, I would suggest Model Master Intermediate Blue.
For me it was the perfect color on it's own and did not need mixing, plus it also comes in a rattle can if you would rather skip the airbrush
rbeach84
Looking good! The weathering is quite striking at this stage (no pun intended...) I tried the 'hairspray' technique for the first time and found it was harder to control than say the 'salt' or 'maskol' methods which have a targeted application of the masking barrier.
I'd recommend using a coat of Future (aka Pledge Multi Finish) as a protective barrier to subsequent work.
Thanks for sharing!
Regards, Robert
