ANYONE RECOGNISE THIS POWER SWITCH
judgedredd
i hope you guys can help me with my next question i need to source this power switch and i am hopeing someone on here knows were i can buy them :thumbsup
Couldn't you modify any square button switch? Cut out the little groove for the LED, is it? and away you go.
If the switch cap is hollow make one or fill it?
about the best i can do with the images i have sorry .
as for moding a switch its something i could do i was just hoping its a common off the shelf switch it does appear to have an LED attached to it as well?
cheers
<div class='quotetop'>QUOTE(Vaderman @ Mar 28 2007, 05:50 PM) [snapback]1450113[/snapback]</div>
Do you have a better or larger pic?
[/b]
any context for size? uncrop it so we can see something else in relation tot he part. Is it a centimeter? 3? 15?
sorry :$ no problem :) iam guessing about 15mm square :
<div class='quotetop'>QUOTE(moffeaton @ Mar 28 2007, 06:04 PM) [snapback]1450124[/snapback]</div>
[/b]
Looks like a gaurded switch cover to a fuel panel on a Boeing 747. The outboard wing tank fuel dump switch to be exact. But these pictures look like it has been painted.
now that sounds hard to get hold off :(
<div class='quotetop'>QUOTE(Darth Detroit @ Mar 28 2007, 06:11 PM) [snapback]1450131[/snapback]</div>
[/b]
It may depend on which part of the planet you live on to get hold of these easily, in so as far as access to purchasing is concerned.. I've travelled a bit & worked with these switches before, but it's all down to local for accessibility... so where are you at, on the globe?
United Kingdom i have a friend in USA i could get them shipped too though :)
do you have any other info a make or model number or even a discription to search google?
cheers mate
<div class='quotetop'>QUOTE(bagpus3 @ Mar 28 2007, 06:56 PM) [snapback]1450175[/snapback]</div>
[/b]
<div class='quotetop'>QUOTE(judgedredd @ Mar 28 2007, 07:06 PM) [snapback]1450182[/snapback]</div>
cheers mate
[/b]
[/b][/quote]
I didn't know you were in the UK. If that's where the switch id from try Chris Cooper from the UKG. Send me a PM :)
He's a flight techincian in Gatwick
I had a Starship troopers communicator with the same button. Just FYI that red part is probably glued in since it travels up with the button if I recall. I think you can pretty much find it at some online electronics sources just send them a picture.
