Another Groot costume - but with one big difference WIP
Discussion in 'Marvel Costumes and Props' started by PSULion22, Sep 18, 2015.
  1. PSULion22
    PSULion22 New Member
    3
    Hi all-I'm a new member here, and I have been using all of the information on this site to build my Groot costume. I'd like to share what I have so far with you. Building is mostly done, now it's time for detail. I have 5 days to get it donebefore it needs to go public!
    So it's using the common build technique - PE pipe insulation glued to some kind of suit - that the very talented Calen Hoffman came up with and most use. But my costume has one very big difference from others that I'm really proud of. Almost every other Groot I've seen uses EVA foam to create the mask. There are two problems with this technique. First,it's difficult to get the proper shapes, depth, and expressions from the foam. The foam is thin, and even with layering it, it still isn't thick enough toreally get the necessary detail and shape. Second, the mask doesn't move. You can't emote or convey facial expressions. You can't open the mouth to eat or drink. Speaking can be muffled. So I have gone a different route. One that alleviates all of those problems, but was more difficult and expensive. I'm using foam latex (or more accurately, foam vinyl.) The process starts with a lifecast of my face
  2. PSULion22
    3
    Then comes the sculpt in clay for what the mask will look like
    The molding and latex pull will come later.
    Jmen likes this.
  3. PSULion22
    3
    I made the rest of the head out of foam. But not the usual EVA craft foam. This is cross-linked PE foam from http://www.foambymail.com/VA/polyethylene-foam-roll.html. It is more dense and firmer than regular EVA in things like floor mats. I highly recommend it.
    The head piece will be fitted and attached to a hat I made once the foam mask is pulled. Then I'll carve and detail the sides to finish it. I'll adhere it to the mask when I wear it to keep it from moving around.
  4. PSULion22
    3
    So the body is built the same way as most others. I won't go into detail. Here's my version.
    I'll make the bark pieces out of the same PE foam, carve, and paint them.
    So that's where I'm at. tonight I'll be finishing the bark pieces, and priming the suit.
    Which brings me to a question. What is the best way of creating texture on the pipe peices? I'm considering tissue paper or cloth with liquid latex, plasti-dip, cloth and spray adhesive, dremel/heat gun, or silicone caulk and a comb. Any other ideas? Which did anyone else prefer? Which is the fastest?
    I'll be using 7" platform boots to give height. I'll be making those tomorrow along with the hands. I'm waiting on more foam to come. The plate mold for the mask is done, that will get pulled tomrrow too. more to come. . .
  5. zoal
    zoal Member
    112
    Looking good mate.
Share This Page
