Just found this quote I had saved in a different doc I had written up regarding the cloak collapsing:
John [Stears] also recalled a scene in which Ben Kenobi dematerialises. “When Darth Vader slices through Kenobi with a lightsaber I did this by replacing Alec Guinness in a strategic position in the action with an empty cloak shaped like Alec. It was hung so that as Darth Vader’s saber hits the cloak, an electronically-fired pyrotechnic charge cut it in two, the bottom half having to fall a split second before the top, so as to show what had happened.”
Paul Welsh explains how special effects teams made lightsabers glow and Obi-Wan Kanobi disappear. I have been sorting out some old paperwork and came across some interviews I did back in that hot summer of 1976. One was with John Stears who was responsible for the special production and...
www.elstreestudios.co.uk
1) The Chronicles photo really was a re-constructed hilt for record's sake, we think. So, the placement of the windvane may not matter, it's easy to spin up and down and doesn't lock anywhere. Very good eye on seeing the ridge on the bottom of the "pommel".... all AS handwheels of that model (with or without and endcap) look like that
Ahhhhh - I haven't studied the real parts of Obi as intensively... Wasn't aware the windvane doesn't really lock, so that could explain that detail.
2) Thank you for the R2 details, that's something I'm very unaware of. I don't know if the sabers were considered basic casts.. it took Brian a LOT of work to make the pulls he is doing now, which are arguably better than the cast that propsore sold
The R2 details are quite interesting! For anyone curious about the construction of the original R2 units, the OpenR2 group on facebook (and related sites) is a goldmine.
I believe they recently acquired this interesting piece.
<p style="text-align: justify;">An original R2-D2 utility arm created for the production of the 1977 science fiction picture Star Wars, the first instalment in the classic franchise directed by George Lucas.</p> <p style="text-align: justify;">R2-D2 is t
www.thepropgallery.com
A raw cast aluminum R2 arm, for anyone who wants to compare it to the raw cast sabers.
An exact quote from one of the original ANH R2 engineers regarding these can be found here:
OpenR2 is an open source effort with two focused objectives. 1) Researching the specifications of the robot prop built at EMI Elstree studios in 1976. 2) Implementing an open source robotics...
www.facebook.com
“I drew them up and got them from a local casting company (looks so similar I wonder if it was from their pattern?) and we then machined them (can't remember if the radii were on an nc machine or on a rotary table) . On the RC R2 the "hand" end part was cut off and a 1" long seloc pin (3/16" dia ?) fitted between this and the "forearm" to allow the "hand" to be "stiffly" twisted, although I don't think this was ever used (in fact I'm not sure I've ever seen the arm swung out anyway apart from what I think was an out take).” - Neil Anderson, shared by Robert Jackson
5) I believe the hut, cantina, etc. used Scotchlite fabric. Especially the hut, the lumpy frayed look of the material, and the sheen, really look like my Scotchlite fabric meant for vests and stuff. I glued it to some PVC pipe and it looks just like this.
Fair point, I'm not even certain it was available in a tape variety at this time? I think most of the references to blade material from the time are "fabric."
7) The blades in ANH duel are a lot skinnier than I thought. The best way to tell these sabers a part is the diameter of the emitter face. I personally believe there were casting flaws in the in emitter plate, and they lathed the plate smaller to save the cast. That's how you end up with the V2 or the others. This is a small emitter here
Wow, that first pic
does look quite skinny! But the death saber blade is interesting... When it's on the ground it has a nasty bend in it, I wonder if that is wood that snapped?
8) MouseVader made a very good argument that they might have had trouble holding the guts in on the Barbican, or holding the emitter on... I don't remember why, but I don't think the 1 set screw was enough when swinging it around
Something was definitely up with the shroud - Prowse holds it so awkwardly. The guts having problems staying in makes sense, considering the location of the switch hole being so high up on the hilt compared to the Luke stunt. I haven't actually seen any evidence there was even 1 set screw on the shroud during ANH. I imagine there is a set screw under the shroud that holds the guts in similar to the Luke stunt though.
I wouldn't say that. There are still problems I encounter every cast I pull. In fact, that's all I seem to ever post about on my Instagram. [snip] I'll be the first to say, and will continue to say, that I honestly don't know why or how they did it.
Still, your experimentation on the casting has provide some great insight into the process of what it could've been like!
I do think the casts they wound up using to make the hilts were the best of lot they had, out of however many they made in the time they had to do it
Possibly, but I'd argue the V3 is a worse casting than the two blanks we know of that are in private collections? The seam line and casting gunk is substantial compared to the other blanks.
The latest date for the saber designs settled on is implied to be Feb 5th, and the shooting memo says the props needed to be sent out by March 20th-22nd; that's about a month and a half to figure something out for the stunts.
The thing is the stunts don't have to be ready by March 22nd, they have to be ready by April 20th for the Cantina! Tunisia filming begins in March and stunt sabers are not necessary then. So that gives them technically about 2 months to come up with something, with a couple weeks of being unsupervised, as they finish filming in Tunisia on April 4th. I'd guess they'd be finished, or almost finished by the time Elstree filming begins on April 7th - maybe even later considering how rushed of a job they seem to be and how it seems they tinkered with blades throughout filming.
Definitely different sabers. this is what I see:
1)
"Tall collar" is what I've been calling this one! Agreed 100%
I concur!
I think the first pic in #3 is the V2, but in the other images though the emitter plate looks quite wide to me. Though it could just be the V2 before getting dinged up, not sure.
I went through this frame by frame too finally! I definitely see what people are saying. it's my opinion we are seeing blades with collars sitting ontop of bearings, right up against the emitter face... at least for the shots where we see the blade spin in detail. The high ones.. not sure. I see the blades bend too, multiple times.
It was cool seeing the motorized graflex in action. here's the MPP clamp on the barbican
Nice catch on the clamp! I'm certain there's another BTS shot that shows it decently clear.. I'll have to look for it
