Hi all,
This is probably a total noob question, but here goes
I could use some help with my airbrush. It's a Badger 155 Anthem. Its performance has been deteriorating over time to the point where it nearly won't spray at all anymore. I need to be at about 55 psi before it will spray thinner. IMO this is way too high! My paint is thinned to airbrush consistency (or at least I think it is - about the consistency of water).
I'm very careful to clean it after each use, removing and soaking the parts at the front of the airbrush in thinner or acetone and cleaning the needle. I just disassembled and soaked the entire thing (the hard parts) in acetone for about 24 hours to remove any buildup that might be in there, but it didn't really help.
Any suggestions, or is it time to buy a new one? This one isn't that old, I swear it's been used less than 30 times. I'd hate to have to just replace it, but if this thing is just junk, I'd rather buy a better one. I'm pretty sure the Badger is an entry level brush - is there another brand or model that's better? I used to have a badger back in the day and I remember it doing the same thing. How about Pasche - how do they compare? What are you all using and what are your experiences? I've read that some require less pressure to operate or are better suited for spraying larger surfaces? (like a spaceship hull!...) while others are better for things like automotive pinstriping...
Any input would be appreciated, I'm kinda new to a lot of this stuff, and don't have a ton of experience with airbrushes. If I can't get this one working well buy saturday morning, I'll be buying a new one that day. Is there a price point to stay above in order to get a professional level tool? Any recommendations are welcome.
Thanks
Thanks
