Agent K's Pistol WORKING mechanical TRIGGER/HAMMER Blade Runner 2049
Status
Not open for further replies.
Paul FSebastian
I've been thinking and working for a long time on how to have a fully functioning trigger/hammer on this weapon prop without the need to use a solenoid and large battery.
I've seen Joatrash FX's excellent version of that solenoid functionality on here which inspired me to attempt to replicate it myself using some purchased resin models of the weapon, my Dremel, and a good old fashioned safety squint.
It did eventually work great, but my version needed a 6v solenoid to recreate a fast hammer action that was snappy enough to look good to me. That required a 9v battery to power that and the LEDs which was fine. But the solenoid drained the battery VERY quickly. The other issue was that the solenoid version I built only moved the hammer forward until the trigger was released, rather than have the hammer release halfway through the trigger pull. Blame my terrible knowledge of electrics.
So I've finally gotten a version to the point where it works as a concept and I've been able to PLA print all of the parts and assemble to test. It works great with a satisfying pull/action only using neodymium magnets as you can see in the video below.
The LED is the only electronic part, which only requires a single 3v CR2032 battery which is easily accessible in the barrel area.
I've located the switch back in the rear of the blaster (marked by the blue arrow) to try to emulate how I'd seen the hero props switched on in Adam Savage's YouTube video. So a paperclip or similar is needed to switch it on, as that's what it seemed to me was used in that video.
I also wanted the whole thing to be strong and feel like one single chunk of weapon without the need to necessarily glue or bond the prop together. So I've taken a lot of time to incorporate mechanical fixings throughout (Mostly M3 hex screws of different lengths) which add weight and a lot of stability and remove the need to use any glue/etc to have a finished solid prop weapon. Some small dome head bolts can be added too as shown in the finished photographs to add weight too and a bit of 'realistic' decoration.
I've incorporated routing for the wiring to reach the switch at the rear, and have included a cavity in the grip for weight to be added if preferred. As I am only printing in PLA at the moment I felt that the prop needed additional weight.
Overall, the months of work trying to find a solid mechanical solution to the trigger action has ended with a result that I'm finally happy with. Please excuse the rough finish and ghosting on the parts, i'm only using a fairly cheap standard Anycubic Kobra Neo and need to tweak some of my print settings for some parts and nothing has been sanded as yet.
This is absolutely stunning! Congrats!! And I'm so happy to see you've got that backside of the grip edge flattened like so many models seem to miss!
I'll echo the obvious statement that if you're willing to sell the files I'd be overjoyed to have a go at making one.
Since the blade Runner 2049 auction went live and the highest resolution images of every prop became available, i've had another good look at my blaster files to tweak anything that I could improve.
The grip being the most obvious part that needed, well, re-designing. It was miles off.
Very grateful to have the photographs out in the world, They also highlighted how very far off my emanator design files were. So i'm also amending those to be closer to the movie props.
Images below of the updated grip so far on Officer K's blaster.
Any updates?
Hi OzDean
I've been working through the entire thing getting it as close to the new photographs as possible.
I'll post some updated images this weekend and should hopefully start test printing each part too.
There are 32 parts in total , possibly more by the time I'm done
It's like dominoes, If i change a part I try not to effect the ones that join it, but most of them needed some attention
Standby....
Any chance you might do a run of these here on the site in the future by chance? I'd be interested for sure in one if you do...
With a home setup of a single and pretty basic PLA printer, the production line would be worse than slow, lol
It isn't a no, but it would be very slow and difficult around work.
But not impossible!
I could also look into having larger numbers of them printed by an outside source if there were ever the demand for them I suppose?
Update pictures below
This is the prop now ready to test print. So that process will begin asap and hopefully go smoothly.
I've basically redrawn the muzzle, whole barrel, the side vents from scratch to align more with the stock photographs more closely. The whole rear section has been re-worked to better match too, and obviously the new grips were the first re-drawn parts.
I've also separated the detailed parts on the back of the hammer and the sides of the main rear body that require the very small text so that those prints aren't needed structurally and can just be added as printed parts that can be slightly weaker with 0.2mm layer lines to capture the detail well. I'm hoping that this will keep the printing time down as the detail parts will be smaller (see last two pics) and the main bulk of those parts will then still be strong and structural.
I'm including the detailed parts without the writing in place in the overall design as separate parts, so the option is there to print without the text for convenience
I've tried to keep the parts list to actually put this together and make it work as small as possible and am pretty happy that it's not too bad.
Thanks for looking and thank you for the positive comments as always!
Status
