ABS is very similar to styrene, just a little tougher and less brittle. Painting is the same, whatever you would use for a styrene kit will do fine. It's a bit resistant to plastic cement, Testors tube glue may not make a good bond. But something like Tenax or Ambroid pro weld will work fine.
I'm considering investing in a 3D printer that outputs models in ABS. Has anyone had any experience using ABS? Can anyone recommend a paint and adhesive for priming and gluing?
Thanks
