LuciousFox
Hi guys building a pair of Nike mag boots and orderd the strap so from Markpoon ,
I've tried his panel out and it works fine,I then orderd a A5 el panel from EL crafts UK and I've cut it into 4 pieces 8cm x 11cm and tried to run one of them with markpoons inverters and battery and nothing happens, the circuit is from the battery,inverter to el panel and nothing lights up but this circuit works since I've used markpoons panel to check, the system is 3volts and since people use 3volt systems on here I thought it would be fine. Can any one shead some wisdom ??
Best regards
Brad
Best regards
Brad
