dakota_in_the_sky
Finally got started on mine.
Parts are left to soak overnight
Hosted on Fotki
Nose is glued together with super glue. I ran a bead of epoxy putty along the seam to strengthen it.
Hosted on Fotki
Nose is puttied
Hosted on Fotki
I added styrene strips to the body the add thickness. It's a little thin in those areas. I then glued the top body onto the nose
Hosted on Fotki
Alignment pins on the lower body are removed
Hosted on Fotki
Propland gave me the tip to add styrene to the sides. I used .188" x .125 strip.
Hosted on Fotki
Nose is puttied
