Subscribe
  1. dutchmarvel's Avatar
    Member Since
    Mar 2013
    Messages
    51
    Mar 28, 2013, 4:07 AM - foam build help pls #1
    hey guys im woking on the iron man mk3 (yes another iron man) but i have some questions
    im currently working with 4mm eva foam and have some problems with cutting 45 degree angles any tips?? mat cutter from x acto is not for sale in holland
  2. Raigal's Avatar
    Member Since
    Mar 2013
    From
    Eindhoven, Netherlands
    Messages
    136
    Mar 28, 2013, 4:12 AM - Re: foam build help pls #2
    im from holland aswell and recently started on my iron man aswell.
    im using 10mm plastazote foam at the moment (for boot and legs) and i bought my x acto angle cutter on ebay, a seller from the UK has em, i recieved it within 4 days.
    Raigal.
  3. ironmaided's Avatar
    Member Since
    Aug 2010
    From
    The Philippines
    Messages
    2,008
    Mar 28, 2013, 4:14 AM - Re: foam build help pls #3
    you could use scissors on angle cuts but i won't be as clean as the xacto. . .and also 4mm eva foam is to thin for ironman. . .that's why i don't use those. . .
  4. dutchmarvel's Avatar
    Member Since
    Mar 2013
    Messages
    51
    Mar 28, 2013, 4:16 AM - Re: foam build help pls #4
    why would it be to thin and im also gonna use the coating from xrobots so it will be harder
Similar Threads
  1. Ironman Foam Build Recommended Foam sizes?
    BL1TZKR13G, Marvel Costumes and Props
    Last Post: Feb 19, 2016, 8:35 AM
  2. Replies: 14
    Last Post: Apr 7, 2014, 9:51 PM
  3. ironman build help pls
    dutchmarvel, Marvel Costumes and Props
    Last Post: Mar 21, 2013, 9:50 AM
  4. Replies: 5
    Last Post: Nov 3, 2012, 10:18 AM
  5. Replies: 4
    Last Post: Jul 18, 2012, 1:30 AM
