For the record, I'm a man! haha! And actually, thank you SO MUCH for the tip! You really helped me decide what to do! I think I am going to buy two strips of el tape that I will line from each side of my jacket from, over my shoulders, and down the back. That way, I am not doing any cutting or soldering, but I will get the light I want. For the rest of the glow, I will use reflective tape! Then, maybe actually getting a chance to play with the el tape, I'll become more comfortable with the el tape and order more to replace the reflective tape for later events down the road! WOW! I feel so much better! This now seems possible! Thank you so much!
Hey man, glad I could help. I'm not too sure about the disk setup, but there are a ton of references on this thread. If you do an advanced search for it, you'll probably get a good amount of hits and info about it.
Also, I got my EL Tape from Funhouse, and I'm very pleased with the initial try out just to make sure everything works. I'll give a run down, then I'll post some pics of it.
I got two different drivers, the Fish Driver+1, the peacock driver, and two strips of the 1m aqua Cool Neon ribbon. I also got one of the 12v 8AA battery holders (as suggested by the web site). I'm not trying to promote in any way, but the stuff works very well right out of the box.
I first used the 9v connections with the Fish driver and it lit up quite brightly. There is a bit of buzzing noise accompanied, but that can probably be dampened with the right stuff. I then used the 12v attachment, and it lit up pretty brilliantly.
The peacock driver was dimmer, but still pretty nice. Granted, it is powering a whole 1m ribbon (not meant for that length), and I am certain once I cut it down the driver will work great. The 12v attachment didn't make much difference here.
All in all, I am very satisfied with this setup. The ribbon has no fade in the center and it is about 13/16" in illuminated width. Just about right for a Tron-style replica.
Here's some basic pics (since I'm lazy and don't want to fill the page with pics, here's a link for my photobucket page):
Pictures by DigitalBabylon - Photobucket
Next step will be to start working on adding an EL Ribbon to my Fedora, and adding an actuator switch.
Also, couple of quick notes. One, the dark picks don't capture the brightness well, except when using the 12v with the fish driver. However, they are quite a bit brighter than they appear in the dark pics. Two, be cautious when working with the drivers. If you have power attached, and the metal prongs from the driver are not plugged into the EL Ribbon connector, then the potential for a nice little zap is there.
