EyeofSauron
this has been discussed a bazilion times.Which method is better, a foam armor or papercraft? I know that papercraft requires bondo and fiberglass plus sanding and that Foam is easier. I like how the Fiberglass is sharper looking but the foam is decent also. In the forums opinion which is better?
neither one is better. it depends on what result you want. pepakura will get you more durable rigid piece, while foam will wear because of its bendy nature, but its cheaper and easier to build
both are equally good tools for costume making, and the final decision is only yours to make.
