Re: The PEPAKURA resource and tech question thread - GO HERE FIRST!
Uni, I found this
http://www.therpf.com/f24/robo3687s...vi-war-machine-news-7-11-a-88147/index50.html
from nick---
This is to everyone who is asking questions about scaling:
Each piece needs to be scaled separately!
Everyone is proportioned differently so to take the default proportions and just scale them across the board will result in something your height or your width but in the same shape as the original. You MUST size each piece to match the part of your body it's designed to fit over. Scaling each piece to the same number will NOT work for most people.
There is no magic way to figure out a scale
Just measure the body part you need to scale to, look at the dimensions of the piece in the program and adjust the scale until you have a good balance between the length, width, and depth in terms of matching your proportions.
It's more work, but if you don't do this your final product won't fit right.
Even if you scale to the same dimensions that someone else your same heigh and weight did you will STILL have issues because, like I said, everyone is proportioned differently. Their arms might be longer than yours, their legs shorter, have more muscle, have a wider chest, and a bigger butt, but weigh exactly what you weigh and be the same height.
Just take some time to figure out your scale for yourself and you will be just fine. And if you need to repep a piece because it doesn't fit, at least you know how it goes together now, meaning your second go will be faster and cleaner.
-Nick
