DBoz
Well, it's been almost a year since I did anything with the Pulse Rifle. I got it out last night and had a look at it, to decide what should be next. Here's what I have planned:
Drill out and install brass threaded inserts to all the places where screws are threaded into the resin. With all the assembling and disassembling, some of them have been stripped.
Permanently install a spacer between the mag and base. Without the spacer, the mag base does not line up correctly with the shrouds. Right now, I've got a couple of washers stuck in there that do the trick, but I want something permanent. As can be seen in the pic, I also have some shaping to do on the mag well of the shrouds to get them to blend with the mag base.
I got one of SD Studios' new, more accurate stocks. It is really nice and more screen accurate, but it has a different pattern to the slots on top, so I have to re-drill and tap the top of the receiver for this new pattern. Luckily the shrouds will cover that part of the receiver, so the old holes will not be visible.
Once that stuff is done, then I need to do some painting. Based on the color comparisons that are floating around, I had decided to use Aervoe 999 Earth Brown, as it looks like the closest match (without mixing) to Brown Bess. I'm not 100% sure now, as in person, it looks really brown. I think I will paint it and if I don't like it, I will repaint. For the metal parts, I am planning on using Aluma-Hyde II Dark Park Gray, just to be a little different than the normal black. Again, if I don't like it, I will repaint.
