Re: ED-209 rebuild
Hi Chris, i would stay clear of CFS, but Tomps don't seem to offer any resin in white.
Here is a finished hip joint, made from resin to replace the original rubber ones. This part has been the most time consuming part to make believe it or not:
No more rubber!!! Did i say i hate rubber?:
Here is the gun pod and ammo boxes. I have bolts sticking out of the pod and magnets built into the amo boxes to hold them on:
The detail with the three slots above the bolt head on the pod in the above photo had to be added on this side, as this side was where the rocket launcher was on the pod i molded. I made a partial casting of the pod and cut this section out and glued it on this side.
Ammo boxes fitted:
The hole at the back takes a plastic tube through it which is how its going to be mounted to the arm. You can see how thick the cast pod is by looking at the hole:
Here are the new guns for the left pod. They will have a few wires fitted to them after i've painted them:
Here is the new gun for the left pod. As you can see, i've used two original parts. I still need to add a few bits to this to attach the wires to:
Some more photos of the new left pod, ammo boxes and guns. Everything here has been reproduced/scratch built:
As always when i take photos outside, it started to rain, so ignore the rain drops
I forgot to get some pics of the finished mouth, so thats all for now.
Keith.
