Re: Cracking Open the MR Falcon to fix front LED. SEE POST #16 AND #17... IT'S THE B
Just sent this to Master Replicas. I'll be curious to see if they continue the blow off now that the cause of the problem has been identified.
JV
"Hi. I bought your Millennium Falcon Signature Edition back in November of 2006. I put it straight into storage without opening it and upon moving, finally had a place to display it this past December of 2008. Right out of the box, the front portside mandible LED light did not work.
After quite a bit of research, I have discovered I am not the only MR customer that paid a lot of money for this collectible, to have the front mandible light not work and discover that MR's stance was that it's "out of warranty". Well as mine was only unpacked and put on display after spending two years in storage, this is an unacceptable position.
I took the front panel of my Falcon off where the problem LED was. After removing the LED to replace it, I figured I'd test it anyway with an alternative power source and I discovered it works. After reconnecting it, and connecting a 9 volt battery to a male phono plug jack and connecting it to the lower gunport of the Falcon, all the lights on my Millennium Falcon collectible now work fine. Which means that the problem, is in the power supply in the mirrored base as it sends current to the Falcon. The switch on my base was always wonky to begin with, and never stayed on. You had to wiggle it back and forth and he power to the Falcon was always inconsistent, and indicative that the problems with the Falcon's lighting have to do with the mirror base with all the flickering of the lights as you had to try to position the on/off switch in a manner that would keep the lights on for a few moments before going out (with the one mandible light never turning on at all).
Please read this thread at the Replica Prop Forum all the way through to the end.
http://www.therpf.com/showthread.php?t=60946
The only solution I see in being able to make my Falcon light properly with the AC base, is to take the base apart to address the faulty wiring issues under the mirror panel that lead to the frosted support pylon. But it is impossible to remove the mirror panel without cracking it. My only solutions are to find a vendor who can provide a replacement mirror panel so I can effect repairs, or find out if you, Master Replicas, can direct me to the vendor that made the bases for your Millenium Falcon so I can try to buy a replacement base, even if the item is out of warranty and you don't have the license anymore, the bases are not licensed items, and I would like to restore my signature edition to be able to power up the way it should have out of the box without this problem or "out of warranty" excuses.
Please respond and please don't tell me you can't do anything because it's out of warranty. I want a display base that works, the problem is not in the licensed Falcon replica, and if I have to pay to buy a working base I will. But I need you guys to respond to all the research I took on identifying the cause of this problem for so many customers. It's not an isolated issue, it's prevalent on many of the prop collecting forums where customers of yours who have bought Millennium Falcons from you have posted."
