Here is where I'm at today. Over night I went ahead and did the graphics for the decals. It's a little early for decals but I am using decals for the fan blades on the warp engine so I really need them now. Not to mention it was fun doing something that resembled a finished product. First I printed them on a plane sheet of paper to make sure the size was correct. Everything looked fine so I then printed them onto a decal sheet.
You can see the warp fan blades on the lower left by the sissors (I printed a few spares; just in case, lol). It will take 2 sheets but I only printed one for now until I'm ready for the rest. These look smaller in the photo but that's a 8.5" X 11" sheet.
I was able to finish the front lower hull details and get the inner warp domes attached to the rods. Next up finishing up the warp engines.
Thanks guys. I have not had much time to spend on this but here are a few more photos. I removed most of the existing front and replaced it with a thin brass sheet. I reenforced the top of the brass from bending by epoxying a brass rod across the top. This is the area that no longer has solid backing.
I also had a chance to install the warp engine vents on both sides. Sorry about the dark primer on this one. The finish color needed to bee just a touch darker so I'm hoping this will do it:
I went ahead and finished wiring the interior and made-up the lighting as well. I made a 7 conductor brass buss to distribute the power. Also in this photo you can see where I added the side windows where the door is.
Here are a couple of pix with the lights on:
I'm using white cold cathode tubes in the back and warm white LEDs for the front. Looks pretty good in person.
That's about it for now.
Will
I had some of the parts made by a buddy. Here are the warp engine rings and part of the rear strut.
Hopefully I'll be able to finish this project up in the next few weeks.
Will
I think every one is happy to know that you own tools Ron.
Hows your "Ultimate Enterprise"....... :confused
Your troll-fu is weak. 2/10
Are there any plans to have an interior, especially with the open windows, or at least a backlit plate image?
I applied the decals to the inner clear dome for the warp engines and then dull coated them along with the outer domes (in the baggie). They kind of look like a candy cane, lol.
Will
The miniature and the full scale mock-up are different (in face I’m almost convinced that the full-scale pad was never really permanently connected but that’s another story).
So the rear landing pad was supposed to retract?
