AndrewGrant
Ok I've tried to drill holes on the mother mold to prevent airpockets between the mothermold and the silicone. I would say its a half succes. In some areas it works in some it wont. :/
So the last resort solution is that Im going to use some easy-tack spray adhesive to stick the silicone in. Im not worried about ripping the silicone because this glue is really weak it just makes the surface sticky enough so the silicone stays in place until I do the casting then I can remove it without any problems.
Sent from a potato.
Sent from a potato.
