With the new model, I decided to get the stand "stuff" worked out first. Holes for the locator pin and connector plugs would be easier to deal with first. I didn't work out the electronics until I was half way through with Lemondrop ( which was a little dicey at times). Since I want Aqua Foil to be simular to Lemon Drop, I wanted to put the locator and connector holes to be in the same place. I was able to place the locator pin in the same place. After I placed the hole (in the lower hull) and the pin (in the stand) I was able to set the two up and prepare to mark the hull for the connector holes. However, when I placed a flashlight underneath, I found that if I placed the two square conduits on the front the stand upright instead of the rear (like I did on Lemon Drop), I would miss the rear door completely. Stand modifications next.
