Subscribe
  1. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 21, 2016, 2:05 PM - Re: Rogue One Rebel Soldier Helmet #126
    The correct version of the M1 helmet is the Vietnam era style, lower profile helmet. Hope this is helpful.
    If your looking for the Correct version here are the things to look for;
    Curve of the Helmet, left is the 1970's M1, right is the WW2 version.
    rpf member BobZurukle
    The seam around the bottom of the helmet is joined at the back, If you find one with the seam at the front its a WW2 version.
    Your straps may vary and could have been repaired with a plastic rim for the strapping to fit to the inner helmet, its your choice to decide how authentic you want your build to be. here is an original inner with original strapping.
    Close up of the strap and screen shot of the trailer helmet.
    screen capture Rogue One trailer.
  2. RPF Premium Member PropReplicator2's Avatar
    Member Since
    Dec 2014
    From
    Abilene,TX
    Messages
    1,082
    Oct 21, 2016, 2:07 PM - Re: Rogue One Rebel Soldier Helmet #127
    And if anyone is interested in kids m1's I found a bunch of plastic ones with fabric on them recently and will pick them up if anyone wants to buy them!
    Alex
    Sent from my KYOCERA-E6560 using Tapatalk
  3. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 21, 2016, 3:09 PM - Re: Rogue One Rebel Soldier Helmet #128
    So I agree with the torch ideas, the clip looks like the go.
    here are some renders that I've made up, Thain looks like you have it sorted too.
    I beveled the edge of the 13 rounds on the cylinder and made the front end beveled with a lip for torch like end. Made two as the first one I made before, when I could not tell if it was a clip or flat surface with a couple lines.
    Click image for larger version.
    you can see afew small differences. the right one is the one Im thinking is more correct.
    starting at the top, both 100mm long/20mm dia.
    end cap - left one flat edge - right one clip with hole 1mm longer. I think thats what I see.
    main body - left beveled edge at top - right one 2mm shorter, and rounded top edge.
    end cap - right one 1mm longer.
    If there are any suggestions pour them on. at the end of the day I will make suggested changes and share the files for printing, and print one myself to see how it looks.
    looking at the poster I already think the clip should be a few mm longer or lower to the cylinder (currently 1mm space).
  4. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 21, 2016, 4:10 PM - Re: Rogue One Rebel Soldier Helmet #129
    Sheeple or anyone could I please get the a couple of dimensions from the helmet. Just planning out the lay of the fabric cover, Im after the lenght from the top vent straight down to the rim/lip of helmet and then from the center front around to the side right angles to the middle of the top vent. Pic below
  5. Thain's Avatar
    Member Since
    May 2013
    From
    Cincinnati, OH
    Messages
    251
    Oct 21, 2016, 4:17 PM - Re: Rogue One Rebel Soldier Helmet #130
    canister said: View Post
    Woah, great job on the render! Way better than mine haha
  6. halliwax's Avatar
    Member Since
    Dec 2013
    From
    Fairhaven, MA
    Messages
    6,095
    Oct 21, 2016, 5:46 PM - Re: Rogue One Rebel Soldier Helmet #131
    thank you for sharing how to tell the difference. i dont think ill be able to head out this weekend because of work, so next weekend I'm going to take the hike and check out the military surplus a few towns over see if i can't find one
    btw guys all these 3d renders look amazing!!!
  7. RPF Premium Member Sheeple's Avatar
    Member Since
    Oct 2015
    From
    Salt Lake City
    Messages
    68
    Oct 22, 2016, 12:58 AM - Re: Rogue One Rebel Soldier Helmet #132
    My fabric cover is a bit different than that one, but the measurements you're looking for are around 5.5" for the height and 6.5" length. Hope this helps!
  8. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 22, 2016, 3:43 PM - Re: Rogue One Rebel Soldier Helmet #133
    Thanks Sheeple
    Just started printing the right model made some adjustments to the front in the pic below you can see the inside lip and reflector part of torch. I have made the internals big enough to fit a AA battery and a 15mm reflector (OD) with the option of two end caps one with a hole for a tac switch and one thats flat.
ID:	675818Click image for larger version.
    once the two parts are printed I will take some snaps and post, and send files to Elr02 so he can print too.
  9. elr02k's Avatar
    Member Since
    Jan 2016
    From
    South Carolina
    Messages
    283
    Oct 22, 2016, 4:21 PM - Re: Rogue One Rebel Soldier Helmet #134
    @canister sounds good. Then I'll print with probably 100 microns and primer-bondo the whole thing to make it smooth. Then it goes to halliwax for casting
  10. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 22, 2016, 6:01 PM - Re: Rogue One Rebel Soldier Helmet #135
    Printed for your inspection, you can see this could work as a real tourch. I have not wired it just slid in a 15mm reflector and led then pulled the rubber on off cap from a $2.50 torch.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	675849   Click image for larger version.
  11. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 22, 2016, 6:26 PM - Re: Rogue One Rebel Soldier Helmet #136
ID:	675849Click image for larger version.
    I will post some more pics once its sanded, primed and painted. I will be a bit easier to see then rather than all white. Also how do you delete a post. double posted.
  12. Thain's Avatar
    Member Since
    May 2013
    From
    Cincinnati, OH
    Messages
    251
    Oct 22, 2016, 6:37 PM - Re: Rogue One Rebel Soldier Helmet #137
    https://3.bp.blogspot.com/-9HkYYnaR7.../s1600/end.jpgClick image for larger version.
ID:	675849https://3.bp.blogspot.com/-F6wOhDfDt...1600/front.jpgClick image for larger version.
    Awesome! Looks great, and I love that you've made it a functional piece. Great to see a prototype on a real bucket...this project is coming together!
  13. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 23, 2016, 5:01 AM - Re: Rogue One Rebel Soldier Helmet #138
    So box on the side of helmet, looks like there are 2 types. One with a rounded rectangular cut out and one plane. worked out it has a clear bevel o the edge 3mm ish and dimentsions are 50x75x15mm. Printing the plain one now and will print the one with the hole in it tomorrow and post for you guys once done.
ID:	675956Click image for larger version.
ID:	675957Click image for larger version.
Name:	rogue one helmetonly.jpg
    on a side note do you guys think cutting a bike inner tube up to stretch around the helmet would work? That could be an easy option to get that part, Going to be pretty hard to get hold of the band from the missile's that got mentioned earlier.
  14. halliwax's Avatar
    Member Since
    Dec 2013
    From
    Fairhaven, MA
    Messages
    6,095
    Oct 23, 2016, 11:40 AM - Re: Rogue One Rebel Soldier Helmet #139
    The torch came out amazing!!!
  15. elr02k's Avatar
    Member Since
    Jan 2016
    From
    South Carolina
    Messages
    283
    Oct 23, 2016, 11:52 AM - Re: Rogue One Rebel Soldier Helmet #140
    halliwax said: View Post
    I second that. I can't wait to see how it comes out on mine later this week
  16. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 24, 2016, 1:59 AM - Re: Rogue One Rebel Soldier Helmet #141
    Hope you guys are pumped!
    A little SBS paint guide for the torch.
    sanded all the high points off the plastic and primed it. Added some test pot paint to the cracks to fill up some of the harder to get print lines. You wont have to do this because the cast will be smooth already.
    After another round primer and sanding with 250-400 grit looking much better. Once I was happy that it was super smooth I painting it matt black, this gives a good base to the boltgun metal I used.
    Bolt gun metal.
    After that I used a bit of mayonaise and a size 1 brush. Using the tip to brush on some streaks so they looked like scratches, normally you would use some masking fluid but applying masking fluid with out letting the previous layer of paint dry off hard (over night) usually results in peeling off the layer under with the fluid. So mayo creates an oil barrier between the paint layers and you can wipe it off with a damp cloth once the top coat is dry in my case 5 mins.
    Weathering I used some stone wash, dark sepia and some brown ink (watered down), I also used a brush and carfully edge highlighted some of the scratches with some crome paint to make it look like fresh knocks.
    Test look beside the box thats just come off the printer and the helmet.
    How do you think the torch is attached to the helmet? maybe a clip that comes down off the armor?
  17. halliwax's Avatar
    Member Since
    Dec 2013
    From
    Fairhaven, MA
    Messages
    6,095
    Oct 24, 2016, 7:22 AM - Re: Rogue One Rebel Soldier Helmet #142
    it looks awesome!!!
  18. RPF Premium Member NeoRutty's Avatar
    Member Since
    Feb 2013
    From
    Vancouver, BC. Canada
    Messages
    2,788
    Oct 24, 2016, 11:12 AM - Re: Rogue One Rebel Soldier Helmet #143
    This is a great build btw... glad I'm following and taking part...
    Before we get toooo far ahead of ourselves, shouldn't we leave a little breathing room for the onslaught of reference we'll be getting in the next two months. I'm sure Disney will display this helmet somewhere we can get crips clean pics of parts...
    And then I'm sure there's a book coming out with all the parts broken down...
    I guess it's all about upgrading later...
  19. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 24, 2016, 1:55 PM - Re: Rogue One Rebel Soldier Helmet #144
    @NeoRutty totally agree
    yeah I tried to see if I could find any more pics of the helmet from any source, think the books come out 16 dec. I hope there will be more pics in the next few months because its an awesome looking helmet.
    http://www.howmanydaysuntilstarwars.com/
    Im trying to get things made up for prototyping so people can comment on size and details, Im away next week. As of now if your wanting to wear/take your helmet to the movie there are 51 days to get it done. It will dissapear fast with all the steps we need to do to get interested people sorted with the items they need to turn their helmets into rebel buckets.
    what else need to be done?
    prototype 3d prints
    pattern for Helmet cover - Alex/Me?
    Printing from Elr0
    Prep for casting
    casting X amount items from Halliwax
    sewing X amount of covers - Alex?
    Sending them out to interested parties
    painting them up
    Who is interested in actually having an accurate as possible helmet for the release?
    For those who are keen to stick around after R1 we can contine to develope the helmet details as more info comes forth.
  20. Walter's Avatar
    Member Since
    Apr 2000
    From
    Phoenix, Arizona
    Messages
    4,652
    Oct 24, 2016, 5:01 PM - Re: Rogue One Rebel Soldier Helmet #145
    I am in to put one together. This is a great build thread.
  21. halliwax's Avatar
    Member Since
    Dec 2013
    From
    Fairhaven, MA
    Messages
    6,095
    Oct 24, 2016, 8:19 PM - Re: Rogue One Rebel Soldier Helmet #146
    I was finally able to see the to ch on my iPad. I was stuck with my little phone screen until now. That torch is awesome!! I love it!
  22. dkaniel's Avatar
    Member Since
    Nov 2009
    From
    Manteca, CA
    Messages
    258
    Oct 25, 2016, 11:35 AM - Re: Rogue One Rebel Soldier Helmet #147
    I'm interested in a helmet I don't need one before the release, just curious as to what it might cost
  23. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    210
    Oct 25, 2016, 1:57 PM - Re: Rogue One Rebel Soldier Helmet #148
    I think the main cost is going to be with Halliwax and Alex (casting and fabric + sewing), Im guessing we wont know too much about that until they have something to cast/sew.
    Hi guys just started playing around with a pattern for the cover, Thanks Sheeple for those measurements.
    Front view was pretty handy gave me a good indication of width and you can see its got the seam and a stitch down also. Im guessing the baffles or what ever they are called start just before the armor. After having a look at the endor rebel helmet builds Rebel Legion. I figured I could have a play to see how they look.
ID:	676809Click image for larger version.
Name:	fabric layout.jpg
ID:	676810Click image for larger version.
Name:	test piece 2.jpg
ID:	676811Click image for larger version.
Name:	test piece.jpg
    There's going to be a long strip for the center every baffle is double the top width 15mm (30mm total). other than that getting the cover to sit nice means getting the side pannels cut at the right angle. I have noticed that I will need to cut a hole for the buckle/strap. Anyone with a real cover could you take a pic of how that part is done please and I will intergrate it.
  24. RPF Premium Member PropReplicator2's Avatar
    Member Since
    Dec 2014
    From
    Abilene,TX
    Messages
    1,082
    Oct 25, 2016, 6:14 PM - Re: Rogue One Rebel Soldier Helmet #149
    Nice job so far! And as of now I'm looking at using tan suede for the fabric cover. Looking like the best option for fabric right now.
    Alex
  25. RPF Premium Member Sheeple's Avatar
    Member Since
    Oct 2015
    From
    Salt Lake City
    Messages
    68
    Oct 25, 2016, 6:19 PM - Re: Rogue One Rebel Soldier Helmet #150
    No problem! And here's some detailed images of my helmet cover that hopefully will help with the strap.
ID:	676896 Click image for larger version.
    The helmet comes in two pieces, the steel bucket and an inner kevlar bucket which has all the harnessing in it.
ID:	676897Click image for larger version.
    The kevar bucket pulls out fairly easily to reveal how the cover lays inside the helmet and around the buckle.
Similar Threads
  1. Finished my Rogue One Shoretrooper helmet and my Tie Pilot helmet
    streetjudge79, Star Wars Costumes and Props
    Last Post: Jan 1, 2017, 1:12 AM
  2. Replies: 7
    Last Post: Jun 3, 2016, 2:44 AM
  3. Any idea what this Rebel Soldier is holding?
    almar bouwman, Replica Props
    Last Post: Dec 6, 2010, 6:38 PM
  4. Endor Rebel Soldier - Costume Tutorial - Now LIVE!
    StudioCreations, Replica Costumes
    Last Post: Feb 24, 2006, 7:46 PM
Tags
