Page 28 of 28 FirstFirst ... 18232425262728
Subscribe
  1. RPF Premium Member
    Member Since
    Apr 2005
    From
    the big wide world
    Messages
    988
    2 Weeks Ago  Apr 6, 2017, 10:26 AM - Re: Rogue One Rebel Soldier Helmet #676
    Mr Mold Maker said: View Post
    A few good screen caps. Canister did an awesome job modeling with the little reference he had. It looks like the holes need to be drilled a little bigger, and the back piece needs to protrude a little more but those are pretty easy fixes I think! In the last picture.. you can see a few spots where a little paint has chipped off.. I've circled the main one, and you can see the base color. Is it blue or is it green? Is the dress white or gold??
    I'll let you guys figure it out...
    Good eye. Looks blue to me. I've also been told there were cast in light grey (poly plastiflex).
  2. Moreorless37's Avatar
    Member Since
    Feb 2016
    Messages
    59
    2 Weeks Ago  Apr 6, 2017, 11:03 AM - Re: Rogue One Rebel Soldier Helmet #677
    for anybody still looking for a base helmet, I found a source that seems to carry the correct helmet for a decent price (And it comes with a liner!) http://www.e-sarcoinc.com/m1-style-steel-helmet.aspx
  3. Mara Jade's Father's Avatar
    Member Since
    Jul 1999
    From
    NAS Jacksonville
    Messages
    15,666
    2 Weeks Ago  Apr 6, 2017, 11:03 AM - Re: Rogue One Rebel Soldier Helmet #678
    Attachment 719633
    I've circled the main one, and you can see the base color. Is it blue or is it green? Is the dress white or gold?? ...
    To me, that blue looks like it rubbed off from something else. It's hard to determine for sure. If we saw it more throughout the helmet or showing up on other helmets, then I think it is a safer speculation to save it was base blue.
    I would also be willing to bet that the helmet in the photo had bands on it. See the wear? I encountered that sort of issue as I moved my bands from one position to the other.
  4. Prop Paintshop! RPF Premium Member Mr Mold Maker's Avatar
    Member Since
    Jul 2011
    From
    Orlando, Florida
    Messages
    1,654
    2 Weeks Ago  Apr 6, 2017, 11:22 AM - Re: Rogue One Rebel Soldier Helmet #679
    LDR said: View Post
    I was told blue, and rubber.. but I can understand how someone holding it could confuse a soft resin for a rubber. I actually switched to 65D when I picked up on the flex the helmets had.
    Mara Jade's Father said: View Post
    That is just the area that sticks out the most. If you looks at the bottom edge, by the left (our view) side of the top hole, and a few scattered areas.. you can see that same blue tone. That circled area is just the most prominent to me. I am still almost certain they were basecoated in blue. It's just now I have a better idea of what blue..
    If you disagree.. well, make your helmet how you like it. Then we are all happy.
    Hell, there are still people painting them army green.. if they like it, more power to 'em.
  5. Thain's Avatar
    Member Since
    May 2013
    From
    Cincinnati, OH
    Messages
    249
    2 Weeks Ago  Apr 6, 2017, 5:40 PM - Re: Rogue One Rebel Soldier Helmet #680
    Moreorless37 said: View Post
    Thank you for posting this! I've been looking all over for a Vietnam-era pot with liner at this price and hadn't found anything!
  6. Mara Jade's Father's Avatar
    Member Since
    Jul 1999
    From
    NAS Jacksonville
    Messages
    15,666
    2 Weeks Ago  Apr 6, 2017, 7:33 PM - Re: Rogue One Rebel Soldier Helmet #681
    It really doesn't matter to me, just trying to keep open to possibilities. I don't replicate props based on the way they are built. I'm more of an idealized builder.
    Here is what I have decided to do for the lamp mounting system.
    Using a magnetic badge holder, some self sticking craft foam, and some two sided tape, I made this part:
    Click image for larger version.
    It mounts to a piece of metal that for now is just wrapped and suspended using black duct tape:
    The result is this:
    I have not finished the lamp as I have not finalized the decision for the light source:
    I am still waiting on a mini light. I have a bore lamp which I can easily clip inside the helmet but the neck is easily seen. Although it's not awful:
ID:	719775Click image for larger version.
    Also, a little bit of the wife's clear nail polish really helps sell the glass lens look:
ID:	719779Click image for larger version.
  7. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    208
    2 Weeks Ago  Apr 6, 2017, 9:19 PM - Re: Rogue One Rebel Soldier Helmet #682
    Boom the nail polish is a great extra.
  8. RPF Premium Member
    Member Since
    Apr 2005
    From
    the big wide world
    Messages
    988
    2 Weeks Ago  Apr 7, 2017, 8:56 AM - Re: Rogue One Rebel Soldier Helmet #683
    I've been looking at the extra picture of the Rogue helmets on set, and noticed a couple of things.
    The torch has slipped so is inline with the bottom edge of the helmet. Marked with an arrow below.
    The torch appears to be held in place with just a bent piece of wire. This wire sits behind the blast shield. Because its slipped down in this photo, its visible.
    The cable/wire around the helmet strap appears to be some sort of headphone wire cut off. Number 1 shows where the wire is cut off. Number 2 shows the 'hexagon' shaped body.
  9. Mara Jade's Father's Avatar
    Member Since
    Jul 1999
    From
    NAS Jacksonville
    Messages
    15,666
    2 Weeks Ago  Apr 7, 2017, 2:04 PM - Re: Rogue One Rebel Soldier Helmet #684
    I noticed the bent wire lamp support when that image was first posted. For a long time, it was going to be my personal method for mounting the lamp. However I started to get concerned with a few things such as the best way to secure the wire frame in the helmet. Would it move around a lot? Also I have some ideas about replacing the lamp with a 3D print or even a metal lathed body. So I was concerned about drilling into future lamps and also if the internals would be damaged with drilling holed into the side. Like I said, I am more an idealized prop replica builder so I wanted to go with simple and functional especially since the mount is not a very visible detail.
  10. Member Since
    Apr 2017
    Messages
    1
    6 Days Ago  Apr 20, 2017, 9:04 AM - Re: Rogue One Rebel Soldier Helmet #685
    Nice work. Do you hace a sewing pattern for the fabric cover?
  11. RPF Premium Member canister's Avatar
    Member Since
    Feb 2016
    Messages
    208
    5 Days Ago  Apr 21, 2017, 8:07 PM - Re: Rogue One Rebel Soldier Helmet #686
    you can find the run for the fabric cover here
    Chris23 said: View Post
Similar Threads
  1. Finished my Rogue One Shoretrooper helmet and my Tie Pilot helmet
    streetjudge79, Star Wars Costumes and Props
    Last Post: Jan 1, 2017, 1:12 AM
  2. Replies: 7
    Last Post: Jun 3, 2016, 2:44 AM
  3. Any idea what this Rebel Soldier is holding?
    almar bouwman, Replica Props
    Last Post: Dec 6, 2010, 6:38 PM
  4. Endor Rebel Soldier - Costume Tutorial - Now LIVE!
    StudioCreations, Replica Costumes
    Last Post: Feb 24, 2006, 7:46 PM
Tags
