Bandai says it's the same scale as the A-wing kit, but it doesn't really seem like it? Not sure.
Did you paint a base grey or just add the weathering? Does it affect the articulation at all?A quick in progress update. I finally got this AT-AT Bandai kit about a week ago and have been slowly working on it. The paintwork on these models of "large" vehicles in a smaller scale are harder to paint, as you'll want to make sure the paint and weathering marks are done in a smaller scale for realism. This is definitely one of my favorite bandai kits now!! As usual amazing detailing, but the way they designed the legs to move is just amazing.
Still a work in progress, as I'll be adding more weathering around the feet and legs.
http://i.imgur.com/DxbQ3vw.jpg
http://i.imgur.com/q6sZ8X9.jpg
I'll be updating with more pics from the slave one build, but I'm jumping around between kits right now! Just got the Snowspeeder, so I've started that!
After build (unpainted)
Primer:
Starting on the aging with pastels (using q-tips to apply)
After a few hours:
View attachment 719677 View attachment 719678
http://i.imgur.com/g2wMeJn.jpg
http://i.imgur.com/4yIPhkk.jpg
For the colored parts, I use artist acrylics. The paint can be easily chipped into with a toothpick for effects, as it's dry to the touch very quickly after application, but not completely dry for a while so that it can still be manipulated easily. To avoid brush strokes, I'll often brush the paint on thin and then dab at it quickly with a cotton ball or q-tip, depending on the size of the area covered. Fine steel wool is also great for dragging across the paint to create additional surface effects!
Will update with more pics soon!
Just a suggestion- i use pastels for weathering as well, and I used to use those standard fat Q tips which tend to get big and fuzzy after a while and makes it very hard for fine detailed streaks.
I suggest picking up a super fine tip brush from the art store.
Make sure the tip is extremely short.
The longer the tip the harder it will be to maintain tension for laying down pastels.
I have about 8 different brushes for weathering.
Some are soft tipped for laying on really soft subtle streaks, some are harder tipped for laying down darker streaks.
Different shape tips also help as well.
If you want to get really dark pinpoint blast marks, then pickup the small modeling Qtips.
They are extremely dense and dont get fuzzy.
Just dip the tip onto the pastel dust then press the tip onto the model, turn the q-tip a few times (like youre trying to drill into the model) then pull away in the direction you want the streak.
