Project: Revell AT-AT Walker
All Primed.
Side Guards, Butt Shields and The Side Doors.
The Chassis
The Main Body
The Belly.
Next, I'll be tackling the Head.
Hello Everyone. It's been a while since my last update. I've been quite busy working on the AT-AT, so let's get started.
THE HEAD Part I
I based my templates of the Head from Baloo blueprints.
I broke the Head into parts and built it up from there.
I penciled in where the greeblies and moldings would go.
I added moldings as I went along.
I epoxied in threaded mounting posts for the Cheek Guns.
Filed them down flush.
The Head is starting to take shape.
I created the center block and the side guards from scratch using styrene.
More to come........
THE HEAD Part II
Installing the interior lighting.
I'm using a single red LED, a micro switch and a lithium cell CR2025 battery to light the interior.
The LED is from a dollar store toy and the I've decided to mount the battery in a compartment on the top of the head.
I've also installed a switch within the center block and drilled a small hole for the on/off button.
More moldings and greeblies were added to the underneath.
I primed the Head to weed out any imperfections or blemishes on the surfaces.
A Back Plate was made and primed. It'll be added to the Head Chassis once that is done.
Stay Tuned for more......
THE HEAD CHASSIS
I've decided to use a chassis to help link the Neck Joints to the Main Body and to help support the Head.
I drew up a template which I basically made by trail and error.
I cut out the parts from 1mm aluminum and epoxied them together, instead of using brackets as I originally intended.
I mounted the first Neck Joint to the Chassis. Also, I added a Pin to the front for extra support.
Next, I did a test fit. Looks good to me.
Want More?
THE COCKPIT
Originally, I didn't wanted to bother with an actual cockpit, but I thought, 'what the hay, I minus well.'
Like everything else, I started with a paper template.
I translated the drawings to styrene sheets.
Next, I added to moldings and greeblies to the plates.
I gave it a base coat using regular acrylic paint.
Then, I weathered the plates and painted details to the control panels.
I got the back door printed up at the photo lab.
If I'm making an interior, I have to have a command crew. I sculpted them out of Sculpey.
Got them all in their places. I didn't care too much about getting them in the correct position and distance from the front window.
After a bit of adjusting, I got Cockpit mounted to the Head Chassis.
The Head and the Chassis/Cockpit.
Next, will be the Chin Cannons and the Cheek Guns.
THE CHIN CANNONS
I had to be resourceful in making these, as well as the Chin Guns. So bear with me.
I started by lamenting layers of styrene to form blocks for the upper and lower cannons.
I used car model parts for the back ends of the cannons. I basically added styrene bits to get the details I wanted.
The main barrels were made from cheap plastic paint brushes. I made the muzzle from several different parts.
For the recoiling rail system, I used two small 'C' shaped brass strips with two brass plates with different widths glued on top of each other.
With a bit of fussing, I got them glued in without any major issues.
I then, made up these two tracks for the cannons and glued them to the bottom of the Head.
I masked off the rails and primed the cannons.
Whew!
Next, the Cheek Guns.
THE CHEEK GUNS
I've noticed thru my research that all three screen-used AT-AT had different Cheek Gun designs. I've decided to base my guns off the 'Notch Knee' model.
From my trusty drawings, I thought I 'd use 4mm square styrene rods to sculpt the main guns and scopes. (if they are scopes)
After scraping, carving and cutting, I got my basic shapes. I then added bits of plastic and styrene. For the barrels, I used 1mm aluminum tubing. Thin stuff. I had to insert pins in the holes to give them support. It worked out pretty good.
Following my drawings and reference photos, I just kept on adding bits.
I inserted brass tubes for the axles.
I fashioned the Side Guards from laminated styrene.
All the parts ready for assembling and priming.
All primed.
I still have to scribe the panel lines on the head, add the rest of the grebblies/small panels and add the cannons and guns. I should have that done soon, so I'll post it when I can.
I have my end mills on order, so after they arrive, I can get started on the Legs.
Nice work there !
The chin guns were exactly the same on the 3 screen used stop-mo at-at. For ROTJ they were put upside down on the one they used. What you have recreated is the big pyro chin guns.
The ATAT casting (featured in the MR set of pics) have a modded upper part.
Nice work there !
Thanks Julien.
I was referring to the cheek guns, not the chin guns. But yeah, I've also noticed one of the Star Wars exhibit AT-AT's had a bent tube for a chin gun. A quick fix perhaps.
Great job Wayne,
I was thinking about the red LED you have in there. Even though the red is cool and ominous, you should consider putting in a white LED also because a red would just wash out all the colour in there. You could wire a 3 way switch in with center for off and each side could be a different LED. Just a suggestion.
TazMan2000
Great job Wayne,
TazMan2000
Thanks TazMan.
I was really considering putting in a white LED, but I wanted to keep it somewhat authentic. Plus, working out the lighting system was already problematic. I didn't want anything attached to the chassis, which meant it had to be self contained within the head. And it was quite cramped in there.
But thanks for the suggestion, I think it would have been cool to have a multi-color lighting system.
Thanks Julien.
Sorry I made a typo, I was meaning the cheek guns lol
Yeah the ones with a bent tube chin guns is a repair, I dont even think the head is a screen used one, the paintjob is very different than the other. You'll notice that the cheek guns are also different and not original at all. That's why I think the head is not screen used. Actually I saw pics of the AT-AT in the Archives before they were restored by the curators (they were in pretty bad shape),
and one of them had a brand new primed head without any guns. The neck boot was also missing showing the armature. I think this is this head and they quickly built guns to get it touring.
Fortunatly enough you have not represented those ugly guns ! :D
I know the one you're referring to. The one in front. Boy, these guys sure took a beatin' after the show.
Haha yeah, that was another pic but the same guys in the same poor state :(
The AT-AT far in the back is not a screen used, it is the proto with a raw primed casting, I dont one where was the third screen used one, it is not in my other pics either :(
From my understanding, there are only two screen-used models on display at the exhibits, the third is in GL private collection.
Hello Everyone, it's been way too long since my last update. And I do apologize for that. Okay, let's get started.
THE NECK COLLARS
I thought I should get the Neck Collars out of the way.
To make it easier, I sliced off 6mm from the base of a plastic LED candle to make each of the Collar's rings. Fortunately, the candles had the correct inside diameter to fit over the Neck Tube.
For the facets, I cut out styrene pieces based off a template.
I layered styrene pieces to obtain the correct thickness.
I next added the raised panels and.......
.......then the greeblies, which I made from scratch.
And lastly, I gave them both a priming.
More to come......
THE NECK TUBE
But first, with help from TazMan2000, I successfully made a mold of a tube that could work. But I do not have a proper casting material to make the tube. So, I'm going to put it aside and hopefully someday use it when have the correct material. So, many thanks TazMan for your help. Most appreciated.
I made a mold of a plastic slinky toy using regular casting plaster.
Before I start on the Neck Tube, I had to correct the Neck Joints, which were a bit too loose.
I refined the Neck Joints by milling the gaps straighter and more even.
I then added thin washers between the Allen Bolts/Joints to help build up the tension.
Next, I permanently mounted the first and last Joints to their bases.
Now, for the NECK TUBE.
I've been struggling on how or what I can use to make the Neck Tube. After a few trials and errors, I came up with this.
I found these plastic slinky toys at the dollar store. They had an outside diameter of 1-5/16", very close to what I wanted.
After cutting one to the proper length, I did a test fitting with the Collars and the Head Chassis/Neck Joints.
Looks good to me.
After gluing on the Collars, I gave the Neck Tube a quick priming.
To avoid the paint sticking, I hung it up so the ribs would spread out.
All done.
When I bent the neck, the tube hardly showed any gap between the ribs, so I decided to bypass a flexible wall and use a piece of grey felt instead.
BTW, the Neck does have a good turn radius even with the plastic slinky.
NEXT, off with its Head.
THE HEAD Part III
I finally got to the Head.
I started by making the Battery Lid, which will eventually be attached via a couple of magnets.
I spent a good week and a half adding panels/greeblies and fine tuning the panel lines.
After all that, I gave it a good priming.
A showcase of all the Head parts.
Next I prepared the Chin Cannons for mounting.
I added posts to the upper Chin Cannons so they can be mounted to the Head.
Mounting holes for the Chin Cannons.
Here's an inventory of what has been done so far.
Next will be the Leg Base Block and Panel.
