The other box is made from 2 Sherman & 1 Matilda tank 1/76 Airfix kits......all cheapo kits
http://i1119.photobucket.com/albums/k637/jaiteastu/Hasbro Hero Millennium Falcon/IMG_1396.jpg
J
I'm sorry if I missed it, but what are you using to fill the holes with? Everything looks so clean, i spent probably 2 hours trying to cut those out clean and they still look Super shredded!Thanks Joberg,.....
Because the boxes have an open area, you can see under the part,....the mandibles need that area repaired,...so I spent a bit of time filling in holes & gaps
http://i1119.photobucket.com/albums/k637/jaiteastu/Hasbro Hero Millennium Falcon/IMG_1621.jpg
I also removed some of the pipes,....which I'll have to replace:
http://i1119.photobucket.com/albums/k637/jaiteastu/Hasbro Hero Millennium Falcon/IMG_1619.jpg
http://i1119.photobucket.com/albums/k637/jaiteastu/Hasbro Hero Millennium Falcon/IMG_1622.jpg
Thanks for looking
John
Yeah I am in awe at how clean johns work is , what do you use to finish / clean the plastic ?I'm sorry if I missed it, but what are you using to fill the holes with? Everything looks so clean, i spent probably 2 hours trying to cut those out clean and they look Super shredded!
So far I have had pretty good results with Milliput. Is milliput comparable to the humbrol model filler?When glue is hardened I filled any gaps with Humbrol model fillerJ
