They're solid... the rest of the nacelles will be essentially hollow, so I'm not worried about them adding much weight.You slush cast those bussards hollow?
Thanks guys!
Recently I've been puttying, sanding, primering and then repeating the process... attempting to get the surfaces to the best state I can.
I also added in the engraved rings on the lower primary hull.
So let me het this straight. You are " puttying, sanding, primering" over what is essentially plaster? How does it stick?
Great job as always and as always; I always look forward to your progress!!!
