cavx
have you tried this on the v2 soles? since the V1s were foamy soles, these v2s are rubber material.
So i'm not sure if this would stick as well onto the rubber.
Also, i'm trying to find a suitable glue for gluing the grey heel back to the grey soles. And then I also need a glue suitable for gluing some speaker fabric to the grey heel rubber piece.
If anyone has tried any, feel free to share.
This stuff is made to be sprayed on the inside of a car interior - IE vinyl seats which cop a heap of wear and tear. I initially tested this on vinyl, then foam, then PVC and finally the Shoe Goo (which is a rubber). It flexes and does not peel or scrape off very easy. If you look at the photo of the underside, you can see some white. The Shoe Goo was painted grey. When a small piece of that broke away, it exposed some white underneath. I never bothered to touch that up because it was under the sole.
