Subscribe
  1. Raigal's Avatar
    Member Since
    Mar 2013
    From
    Eindhoven, Netherlands
    Messages
    136
    Oct 22, 2013, 8:56 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1251
    yeah trying it is always best, ive pretty much got epsilon applying down to a good lvl, but i want to try docholidays method on WM, thanks for the tips jf, and keep them WM updates comming
  2. lordchammon's Avatar
    Member Since
    Sep 2013
    From
    Torrejón de Ardoz, Madrid, Spain
    Messages
    60
    Oct 22, 2013, 9:55 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1252
    JFcustom said: View Post
    I had a long talk about this with Decathlon sales manager last month. TG-100 are renamed Fitness Mat Essential, yellow and blue are no more available, the plastic package is shorter, the backside is now a mesh pattern instead of stipes, the foam is a little bit stronger, and it comes from another factory. But overall it's the same, and red and black are not about to be discontinued for a while.
    It's all the same thing. The new foam makes V-cuts on the innerside easier because of its new pattern.
    Great news, thanks JF.
  3. JFcustom's Avatar
    Member Since
    Mar 2012
    From
    France, Indre et Loire
    Messages
    788
    Oct 22, 2013, 12:58 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1253
    For those who could be interested in building this 1/1 display piece :
    War Machine bust - stagefivedrift's HD model - foam unfold JFcustom.pdo
  4. Rodolfo's Avatar
    Member Since
    Sep 2012
    From
    Gran Canaria, Canary Islands, Spain
    Messages
    270
    Oct 22, 2013, 2:59 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1254
    oh my, this WM build is awesome!!! Those lines are perfect!!
  5. Raigal's Avatar
    Member Since
    Mar 2013
    From
    Messages
    136
    Oct 22, 2013, 3:02 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1255
    wow, the bust file already, awesome work man!
  6. Kirk0's Avatar
    Member Since
    Aug 2013
    From
    Cleethorpes, England
    Messages
    192
    Oct 22, 2013, 4:18 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1256
    Going t order some of these decathlon mats, they look better than the yoga mats I currently use and are very cheap still.
  7. JFcustom's Avatar
    Member Since
    Mar 2012
    From
    Messages
    788
    Oct 22, 2013, 4:39 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1257
    Be dvised you can't draw anything onto black mats (had to borrow from my daughter her magic invisible sharpie, with UV led in the cap)...
    Prefer the red ones.
  8. Chris Fischer's Avatar
    Member Since
    Aug 2013
    Messages
    19
    Oct 22, 2013, 4:58 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1258
    Hello everyone
    Everybody's projects are coming out great
    I'm having a few issues with my latest... Hopefully there someone that could possibly give me some pointers
    I have a model that I wanted to edit within Pep Designer
    The edges and lines. I guess are too complex for unfolding
    As you can see in the picture attached, they are complete mass
    Is there a way to make the model less complicated within the designer?
    I would like to print these out for foam
    Look at the picture
  9. Kirk0's Avatar
    Member Since
    Aug 2013
    From
    Messages
    192
    Oct 22, 2013, 4:59 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1259
    Thanks for the tip JF. The UK website stocks the red/pink ones and they also sell them through Amazon so I'll order those ones.
    Chris, if you have a link to the file in PDO format I don't mind having a look over it to see if it can be made more suitable for foam with some custom unfolding, I don't have the unfolding skills of JF but I'm getting better.
  10. Raigal's Avatar
    Member Since
    Mar 2013
    From
    Messages
    136
    Oct 22, 2013, 5:03 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1260
    i just use my good ol' white paint marker pen
    Click image for larger version.
    works like a charm
  11. RPF Premium Member laellee's Avatar
    Member Since
    Nov 2012
    From
    Minneapolis/St Paul
    Messages
    2,459
    Oct 22, 2013, 7:48 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1261
    Chris Fischer said: View Post
    Hello everyone
    Look at the picture
    In designer, select set edge color (the little box that has three different colored pens in it). From there, you can adjust the slider that determines your polygon definition. 180 degrees will create a fold at every edge of the faces, you can slide that down to about 160 and it should clean up a lot of the extra pieces. AT 160 degrees, the foam can still maintain these 3 dimensional bends that would be impossible with paper.
  12. TheRambler's Avatar
    Member Since
    Mar 2012
    From
    Virginia
    Messages
    108
    Oct 23, 2013, 9:56 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1262
    What about those metallic silver sharpies?
  13. mickc22's Avatar
    Member Since
    Apr 2013
    From
    Gillingham, Medway, United Kingdom
    Messages
    194
    Oct 23, 2013, 12:01 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1263
    I've used Sharpies on black mats, they aren't truly black, so i've not had any problem seeing my lines
  14. charlie88's Avatar
    Member Since
    Mar 2012
    From
    pr
    Messages
    119
    Oct 23, 2013, 2:15 PM - Re: FOAM speed building files ►CullenCosplay vids◄ added. #1264
    wowww that is one sick obito mask!!! can you post a pic wearing it??? i want to see more! please.
    kyxz2 said: View Post
    Again, I would like to thank z3ro44 and JFCustom for the foam converted files.
    I also got another file from erinasution with textures.
    Attachment 245329
  15. lordchammon's Avatar
    Member Since
    Sep 2013
    From
    Messages
    60
    Oct 23, 2013, 3:35 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1265
    Hi all, I finished my first foam project using one of JF files
Name:	Foto 23-10-13 21 18 15.jpg
ID:	245879Click image for larger version.
Name:	Foto 23-10-13 21 18 24.jpg
ID:	245880Click image for larger version.
Name:	Foto 23-10-13 21 18 43.jpg
    My cut & glue finish is very poor but is enough for my 3 year son. He's so happy with his new ironman helmet.
    I need more practice with hot gun. I'm thinking about my next project, maybe Loki's helmet... any suggestions for a newbie?
    Thanks from Spain JFCustom!!!
Name:	Foto 23-10-13 20 50 43.jpg
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	245872   Click image for larger version.
Name:	Foto 23-10-13 20 50 51.jpg
  16. Member Since
    Oct 2013
    Messages
    1
    Oct 24, 2013, 10:55 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1266
    Is there a template to use leftover foam for making a Robin Mask?
  17. charlie88's Avatar
    Member Since
    Mar 2012
    From
    pr
    Messages
    119
    Oct 24, 2013, 7:25 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1267
    Thas a very very good helmet man wow! Ithough it was another pic of Jf showing a new helmet or something lol . You making the hole suit or just the helmet?
    lordchammon said: View Post
  18. Durkness's Avatar
    Member Since
    Aug 2012
    From
    Joplin, Missouri, United States
    Messages
    636
    Oct 25, 2013, 6:23 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1268
    Jaschka said: View Post
    Anything 2D you can do without a program. You can enlarge an image you see and use that as a template or just draw one. My son asked me for one and I just drew it on the foam. If you are using your leftover you have plenty of trial material to work with.
  19. RPF Premium Member laellee's Avatar
    Member Since
    Nov 2012
    From
    Minneapolis/St Paul
    Messages
    2,459
    Oct 25, 2013, 7:38 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1269
    Durkness said: View Post
    HELL YES.
  20. Majed is offline Majed
    Oct 25, 2013, 3:31 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1270
    anything for arkham origins?
  21. kyxz2's Avatar
    Member Since
    Aug 2012
    From
    Philippines
    Messages
    132
    Oct 26, 2013, 6:06 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1271
    Thank you JFCustom! I won't be able to do these without your foam files.
    Thor:
    Captain America:
    Took me only 1 day to do both, from scaling to painting.
  22. JFcustom's Avatar
    Member Since
    Mar 2012
    From
    Messages
    788
    Oct 26, 2013, 5:27 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1272
    Majed said: View Post
    Nothing planned. Unless you have a 3d model to provide ?
    I'm right now transfering on ArmorAsylum's youtube channel the 3 hours long making-of video of this helmet :
    The upload takes forever, I'll post the link tomorrow.
    Meanwhile, watch the third and last part of Durkness's Deathstroke helmet 'howto' :
  23. Durkness's Avatar
    Member Since
    Aug 2012
    From
    Messages
    636
    Oct 26, 2013, 5:54 PM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1273
    Sweet.... Can't wait to see an IM helmet how to.
  24. clonesix's Avatar
    Member Since
    Sep 2002
    Messages
    3,326
    Oct 27, 2013, 12:07 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1274
    JFC: your build is amazing and is likely the cleanest foam build that I have seen. Does the type of mat that you are using hold paint well? Does it require a sealing process prior to paint? There are many types of foam sheet an not hold paint equally. Your thoughts?
  25. clonesix's Avatar
    Member Since
    Sep 2002
    Messages
    3,326
    Oct 27, 2013, 12:11 AM - Re: FOAM speed building files ►Stormtrooper◄ in progress. #1275
    Next question to everyone: has anyone tried contact cement over the hot glue? Specifically, Barge cement? This method would appear to allow the builder to allow two glued sides to dry. Then, the mating process is done without the need to worry about the glue cooling, or the thickness of the hot glue joint.
Similar Threads
  1. Replies: 53
    Last Post: Nov 21, 2016, 9:26 AM
  2. Replies: 122
    Last Post: Mar 20, 2016, 8:42 AM
  3. Replies: 4
    Last Post: Aug 18, 2014, 10:10 AM
  4. Pepper Potts Rescue Armor - foam edit JFcustom
    crimsondante, Marvel Costumes and Props
    Last Post: Jun 2, 2014, 3:21 PM
  5. Replies: 20
    Last Post: Jul 1, 2013, 3:41 PM
