Hi Gang,
Not much of an update... just a few pics here and there...
Sat morning started with my painting some black on the instrument panel. I still need to drill several holes for more LEDs before going any further
The paint helps me find minor flaws that the primer sometimes doesn't catch
Once the paint dried I gave her a good sanding
I love that look - very used
I added more primer and filler to these panels
While the paint was drying on the instrument panel I headed over to the makers to use the laser cutter... I cut these
Added paint
Then chrome - note the smaller hole in the middle
Once the chrome dried... I added another greeblie to the ext panels
OK... let's talk greeblies!
I mounted this guy
I laser cut a template for more LEDs
Cut the holes
Mounted and ready to be back lit
Tough to see but I varied the hole sizes
Mounted more greeblies
Note the two chrome knobs
Time to say goodbye!
And hello functionality!
On to one of the COOLER greeblies of the weekend! I drilled the mounting holes in the new latches I created
Nice and solid
Drilled the holes in the other piece
The last hole... CRACK! UGH... Had to break out the adhesive and filler
When that dried I sanded and added primer
Finding the correct position
Done! (minus red panel light cover)
LOVE IT!
Back side
OK... I know... I took a lot of pics of this greeblie
It just hangs there...
I then cut mounting holes into this greeblie
Spray painted its sister greeblie
And mounted!
Other than a few decals I think this panel is officially done!
Mounting more greeblies - this panel has a large clear plastic greeblie. I think it's part of the Revel 350 Engine model (MANY piece of the engine are seen within the MF). In it's place I used a part of the Garrard trim plate but I DEF want to find the engine model parts
It works for now
I spent a LOT of time with the laser cutter this weekend. It's very time consuming. Cut more T slider knobs
Working new armrest lever bases
From what I can see there are two VERY different versions of the lever greeblie - more coming today!
This is what it looks like - mostly
Not adhered together - still lots of sanding to do
Working on more MISC greeblies found through out the cockpit
Another greeblie - pull handle base
Handle
Basic layout
There just isn't enough info on these handle so I did my best. I'll paint and give them a slight weathering
One of the panels has the clipper guard greeblie and another odd piece that mounts to where 5 or 6 switches used to be so I had to create a cover / mounting plate
Finally... I tore down an old piece of electronics hardware to salvage a few cool greeblies (Fuzz be on the look out!). One of them being this old board I'm going to use for the second door access panel. Turns out there is LITTLE to NO room for any goodies behind the panel because of the electronics box already mounted. I'll figure something out
WHEW... Like I said... Not much of any update. I have the day off and I'm headed to back to the laser cutter!
More to Follow!
