Hi Gang,
HAPPY NEW YEAR! The Final Update of 2014! Enjoy!
After a quick run to the home improvement store I picked enough bolts to mount the new lower light bars on Chewie's side
I actually had to pull this light bar apart and remove 1/16" material - it wasn't lining up against the back panel... ugh...
From the back - perfect fit!
Then it was time to attempt the impossible... Can I take apart the nose panel without having to redo ALL the pin striping????? I removed the lower 1x4
Taped off the pin striping so they wouldn't be damaged, Secured a cut guide into place. The guide worked perfectly!
Lower piece sitting in place - so far so good
I made the cut but it wasn't pretty... at ALL (NO PICS) My hands were SO cold I flubbed a few areas.
I have to remove another 1/16th". Better to have too much material than too little. I'm keeping my fingers crossed I can pull this off. If need be, I'll pin stripe again.
That's it for 2014! WHEW... What a year! I want to thank each and everyone out there who has taken the time to read, comment and contribute to the build! THANK YOU! You guys/gals are the reason we are doing this project. We all appreciate your support and hope to carry on into 2015 and beyond!
Happy New Year, Gang! Celebrate with family and friends! But most important... Be Safe! We'll See Ya Next Year! :D
Happy New Year, sofa, starkiller and all the rest! You keep me coming back for more! Very entertaining to see how things are progressing!
Hi Gang,
UPDATES! The new nose panels are built but need to be sanded, painted and yes... ugh... re-pinstriped...
The first thing I did was build a new panel out of the old nose panel
Panel is finished minus new paint and pin stripes
UGH... Lots of filler needed here
I evened out the panel...
I then started putting panels together to ensure they all fit back together
So far... so good (fingers crossed)
I then jumped over the Chewie's side... just then it began to sprinkle...
Just as before... built the frame to fit
But didn't have time to finish
Making sure panels still align
And this is where 2015 begins! :)
More to Follow!
Do you have to resize your pics? Or does the RPF do it for you? What is the maximum pixel size? Sorry for asking all these questions in your thread, I promise I will lay off.
That I dont know... I just select the link that places the entire image into the thread. I'm going to guess TheRPF has a size limit... but then again, I have seen some images extend WAY to the right! I don't think there is any limit to pixel / file size as well as the original image is sitting in your photo album, not on the TheRPF.
I hope this helps. I'm sure someone can help out! :)
The shelf and new light bars look fantastic, great bit of carpentry. Imagine flicking on the light switch, when that time comes.
Thank you, my friend! Yeah... I've been imagining that monent for a LONG time! The first flip of the switch when everything powers up... can you see it? I see it! ;)
Hey T,
Happy New Year to your and yours! You and every other viewer/fan are why we are doing this project! :) Still lots more to follow!
Happy New Year to You Guys!!
I've not been helpful at all for the built but I enjoyed so much following it!!
Regards,
Alberto
Hi A,
Happy New Year to you! You've been a huge supporter of the build! That's more than enough! Hopefully we'll have the entire ship finished one for everybody to see and experience with all senses!
SK, that thing is way too large for your garage. You really need to move it into my hanger here in Fort Worth. You'd have much more elbow room to work on it. And it would look very at home next to the speeders. Just let me know. :D
Hi Gang,
Some early morning updates! Well... I wound up removing all the pin stripes but there is a outline remaining I can use as a guide... So I have that going for me
Added filler to the braid holes
Sanded smooth - I know... not the most exciting pictures in the world
After the pin stripes have been removed - you can see the outline. But will they remain with a light coat of paint?
The worst areas were the edges of the panel so when I applied the paint I made sure I didn't put on too much. Here you can still see the outline. Should be easy to pin stripe
Also prepped and paint this lower panel that sits under the shelf
Note the difference between the old dark grey and the black paint - what a difference!
More to Come! Stay Tuned!
Happy New Year, may this be a good one. Looking amazing, of course.
Hey Hey! Happy New Year to you my friend! Thanks for the kind words. Let's keep out fingers crossed for an amazing 2015!
Say No More! ;)
Hi Gang,
UPDATES! Well... it was time to do the unthinkable... take everything apart so I could begin painting those pesky bottom panels. Along with all the painting, I was able to get some pin striping done along with greeblie work and some touch up work on the console
Adding some much needed filler
The pin striping was really simple! I just followed the outline from the previous job
But just to be sure I added the greeblies... whew... everything fit
I was looking through some old production pics from ESB and noticed that this greeblie was either silver or white around the edges
This panel is finished!
Done
The cockpit is slowly being taken apart. Now we can get to some more painting! But first... filler
While the filler dries I moved onto the Chewie's nose panel
I then added a quick layer of black to the sides and front of the console. It was in bad shape and showing her age
Hang Tight! More to Come! :)
I NEED my daily dose of this breathtaking thread just as much as my cup of coffee in the morning...LOVE you guys for what you´re doing ;):thumbsup
Markus
Hi Gang,
Not much of an update but an update...
With all the new changes and additions there are now 12 new panels (inc shelves) to transport! UGH
Painting some new greeblies for the front nose
Chewie nose panel - Done!
I still have to paint the shelves then spray Satin clear on all the new painted panels then I think we move to either lighting or the new platform???
Stay Tuned!
Hey S,
That was my very first thought! UH OH... The large shelves I built created a situation where the lower panels MUST now be separate from the others. Even the new light bars "should" be separated. Good news, the panels dont have any greeblies or pin striping so they can be transported with a simple blanket. Bad news, more space will be required for transport in general.
So... I ask myself whether I build a new/second travel shelf AND do I create something to transport/store the shelves? Those are my main concerns right now (that and finishing the dang thing). Just as I ended my post "...UGH..."
Hi Gang,
Sorry for no updates... the weather has been in the single digits for the past several days... TOO COLD! I did some work on a few greeblies but nothing major. The cold spell finally broke and temps are on the climb! :)
Wowzers, SK! That's the kind of weather we have in Minnesnowta right now!
Say, what happened to the space you were using at Mindgear Labs?
So awesome!
Will I be able to get some shots in her at the Star Wars Celebration? I will be in my Han ESB costume. Just need to find a Wookie.
Hi H,
OH YEAH! It was really cold for about a week or so! I can tolerate cold weather, but when it gets into the single digits... NAH... it can wait! ;)
We still use MGL from time to time - Jessie puts the laser cutter on overtime. But they needed the extra space for educational purposes so it was back to the garage! :) We're still looking for a new home.
