Only Honorable Mention!?!? Yea im sure this has been said many times before WOW the attention the Detail you put on this Costume is amazing, I had to pick my jaw up off the ground a few times hah. My Nephew constantly kept asking "are you f#*King Serious!?" Keep Building because you Sir Got Talent!
Looks amazing, Quick question, How did you make the adam and eve on the back of the suit.
The tanks started off as acrylic tubes. I painted the inside with Krylon Stained Glass Paint (respective colors or course) and crumpled up some colored giftbasket wrap and stuck it in the tube to help disapate the light. Each tank also contains three LEDs in the respective color for illumination.
The ends are PVC caps. The standard sizes for PVC and acrylic are slightly diffrent, so the cap has to be sanded out inorder to fit. The assembly was then bolted to the helmet.
Have you ever though of using EL wire instead of LEDs in the adam and eve
